voiceoutput
voiceoutput [2017/07/08 18:30] Deal57 [Setting up the emulator for voice alerts] |
Line 2: | Line 2: | ||
- | Voice alerts are available by installing the appropriate hardware and the latest nightly [[http://deviationtx/downloads-new|Deviationtx.com Downloads]] for your TX. The voice feature runs on all Deviation platforms, however Devo 7e users have limited editing functionality. The Devo 7e can play the voice alerts, but the voice configuration editor menu is not available due to space limitations. The [[voiceoutput#Setting up the emulator for voice alerts|7e Emulator]] has these features so that voice configurations and models can be edited. Models can also be edited manually on a PC. | + | Voice alerts are available by installing the appropriate hardware and the latest nightly [[http://deviationtx/downloads-new|Deviationtx.com Downloads]] for your TX. The voice feature runs on all Deviation platforms except for Devo7e due to memory limitations. |
Line 69: | Line 71: | ||
* In the Devo 12e, connect to the Vdd and ground on the Debug port. This may be a good power source for the Devo 10 as well. | * In the Devo 12e, connect to the Vdd and ground on the Debug port. This may be a good power source for the Devo 10 as well. | ||
* In the Devo 6s, the Vdd and ground on the Debug port are convenient, and can be used if there are not other add-ons in use (such as the Multiprotocol board or other transmitter modules). | * In the Devo 6s, the Vdd and ground on the Debug port are convenient, and can be used if there are not other add-ons in use (such as the Multiprotocol board or other transmitter modules). | ||
- | * In the Devo 7e power is a challenge: search the forum for more details. | + | * In the Devo 7e power is a challenge: search the forum for more details. [[https://www.deviationtx.com/forum/6-general-discussions/6246-devo-7e-voltage-supply?start=20#53017|This excellent post]] is a good place to start. |
+ | <code ini> | ||
+ | voice=dfplayer | ||
+ | voice-uart5=1 | ||
+ | </code> | ||
Line 90: | Line 107: | ||
Line 123: | Line 142: | ||
== Adjust transmitter volume == | == Adjust transmitter volume == | ||
Line 130: | Line 149: | ||
- | - Be sure that the file //mp3123.exe// is in main folder with emulator exe package; it is now included in the nightly emulator builds. | + | - Download the //\mp3// folder and files and place the //\mp3// folder in the same folder with the exe. The //\mp3// folder is included in the voice alerts zip file from [[https://www.deviationtx.com/downloads-new/category/1010-moeder-voice-packs|Test Builds/[Moeder]voice_alerts]] or in the voice packs created by [[https://moeder.pythonanywhere.com/voicepacker/default/index|Deviation Voicepacker]]. |
- | - Download the //\mp3// folder and files and place the //\mp3// folder in the same folder with the exe. The //\mp3// folder is included in the voice alerts zip file from [[https://www.deviationtx.com/downloads-new/category/705-moeder-voice-alerts|Test Builds/[Moeder]voice_alerts]] | + | |
voiceoutput.txt (56560 views) · Last modified: 2018/05/12 09:27 by Moeder
