voiceoutput
voiceoutput [2018/01/31 06:07] Moeder [Setting up the emulator for voice alerts] |
Line 2: | Line 2: | ||
- | Voice alerts are available by installing the appropriate hardware and the latest nightly [[http://deviationtx/downloads-new|Deviationtx.com Downloads]] for your TX. The voice feature runs on all Deviation platforms, however Devo 7e users have limited editing functionality. At the current time, the Devo 7e can play the voice alerts, but 1) the nightly build doesn't include the functionality, so you may need to request a custom build and 2) the voice configuration editor menu is not available due to space limitations. The [[voiceoutput#Setting up the emulator for voice alerts|7e Emulator]] has these features so that voice configurations and models can be edited. Models can also be edited manually on a PC. | + | Voice alerts are available by installing the appropriate hardware and the latest nightly [[http://deviationtx/downloads-new|Deviationtx.com Downloads]] for your TX. The voice feature runs on all Deviation platforms except for Devo7e due to memory limitations. |
Line 69: | Line 71: | ||
Line 76: | Line 78: | ||
+ | <code ini> | ||
+ | voice=dfplayer | ||
+ | voice-uart5=1 | ||
+ | </code> | ||
Line 125: | Line 142: | ||
== Adjust transmitter volume == | == Adjust transmitter volume == |
voiceoutput.txt (56605 views) · Last modified: 2018/05/12 09:27 by Moeder
