voiceoutput
Line 107: | Line 107: | ||
Line 149: | Line 149: | ||
- | - Be sure that the file //mp3123.exe// is in main folder with emulator exe package; it is now included in the nightly emulator builds. | + | - Download the //\mp3// folder and files and place the //\mp3// folder in the same folder with the exe. The //\mp3// folder is included in the voice alerts zip file from [[https://www.deviationtx.com/downloads-new/category/1010-moeder-voice-packs|Test Builds/[Moeder]voice_alerts]] or in the voice packs created by [[https://moeder.pythonanywhere.com/voicepacker/default/index|Deviation Voicepacker]]. |
voiceoutput.txt (56698 views) · Last modified: 2018/05/12 09:27 by Moeder
