which_devo_tx_should_i_buy
which_devo_tx_should_i_buy [2016/04/15 06:02] PhracturedBlue created |
which_devo_tx_should_i_buy [2016/04/15 07:16] FDR [Devo10] |
- | cheap | + | * cheap |
+ | * **Cons:** | ||
- | === Cons === | ||
Line 24: | Line 25: | ||
- | === Cons === | + | * **Cons:** |
Line 39: | Line 41: | ||
+ | * I don't particularly like to button controls | ||
Line 57: | Line 60: | ||
- | === Pros === | + | * **Pros:** \\ - the screen is huge and beautiful \\ - it is actually lighter than the Devo10 \\ - it has better build-quality than any of the other radios (and the others are not badly designed) \\ - the radio has 6 additional analog controls (besides the sticks), five 3-postion switches, three 2-position switches, and 2 digital trims (besides those assigned to the sticks) \\ - the screen is higher resoluton than that of the Devo8 and has much better contrast |
- | the screen is huge and beautiful | + | |
- | it is actually lighter than the Devo10 | + | * **Cons:** \\ - it is twice the cost of the Devo8 |
- | it has better build-quality than any of the other radios (and the others are not badly designed) | + | |
- | the radio has 6 additional analog controls (besides the sticks), five 3-postion switches, three 2-position switches, and 2 digital trims (besides those assigned to the sticks) | + | |
- | the screen is higher resoluton than that of the Devo8 and has much better contrast | + | |
which_devo_tx_should_i_buy.txt (25556 views) · Last modified: 2016/06/30 12:52 by Arnold
