which_devo_tx_should_i_buy
which_devo_tx_should_i_buy [2016/04/15 06:56] FDR [Devo10] |
which_devo_tx_should_i_buy [2016/04/15 07:17] FDR [Devo12s] |
- | cheap | + | * cheap |
+ | * **Cons:** | ||
- | == Cons == | ||
Line 24: | Line 25: | ||
Line 39: | Line 41: | ||
+ | * I don't particularly like to button controls | ||
- | == Cons == | ||
Line 57: | Line 60: | ||
which_devo_tx_should_i_buy.txt (21086 views) · Last modified: 2016/06/30 12:52 by Arnold
