which_devo_tx_should_i_buy
which_devo_tx_should_i_buy [2016/04/15 07:08] FDR [Devo10] |
which_devo_tx_should_i_buy [2016/04/15 07:13] FDR [Devo7e] |
+ | * cheap | ||
+ | * bright screen | ||
Line 36: | Line 43: | ||
- | == Pros == | + | * **Pros:** \\ - the screen is huge and beautiful \\ - it is actually lighter than the Devo10 \\ - it has better build-quality than any of the other radios (and the others are not badly designed) \\ - the radio has 6 additional analog controls (besides the sticks), five 3-postion switches, three 2-position switches, and 2 digital trims (besides those assigned to the sticks) \\ - the screen is higher resoluton than that of the Devo8 and has much better contrast |
- | the screen is huge and beautiful | + | |
- | it is actually lighter than the Devo10 | + | |
- | it has better build-quality than any of the other radios (and the others are not badly designed) | + | |
- | the radio has 6 additional analog controls (besides the sticks), five 3-postion switches, three 2-position switches, and 2 digital trims (besides those assigned to the sticks) | + | |
- | the screen is higher resoluton than that of the Devo8 and has much better contrast | + | |
- | == Cons == | + | * **Cons:** \\ - it is twice the cost of the Devo8 |
- | the Devo12 is the Rolls-Royce of Walkera radios | + | The Devo12 is the Rolls-Royce of Walkera radios. Compared to radios from other companies, I don't think you can beat it for the price, but it is also much more than most people will ever need in a transmitter. |
which_devo_tx_should_i_buy.txt (8491 views) · Last modified: 2016/06/30 12:52 by Arnold
