which_devo_tx_should_i_buy
which_devo_tx_should_i_buy [2016/04/15 07:10] FDR [Devo12s] |
which_devo_tx_should_i_buy [2016/04/15 07:15] FDR [Devo8S] |
+ | * cheap | ||
+ | * bright screen | ||
Line 18: | Line 25: | ||
+ | * color touch screen | ||
I think this transmitter is a great deal for the money. The color screen is pretty, and enables a nicer user interface. Quality is generally good. The radio is not too heavy, and balances nicely on a neck-strap. I do almost all of my development using this radio. If you don't expect to need quick-access to additional analog controls, this radio has everything you are likely to need, and I definitely recommend it as a solid buy. | I think this transmitter is a great deal for the money. The color screen is pretty, and enables a nicer user interface. Quality is generally good. The radio is not too heavy, and balances nicely on a neck-strap. I do almost all of my development using this radio. If you don't expect to need quick-access to additional analog controls, this radio has everything you are likely to need, and I definitely recommend it as a solid buy. |
which_devo_tx_should_i_buy.txt (34842 views) · Last modified: 2016/06/30 12:52 by Arnold
