which_devo_tx_should_i_buy
which_devo_tx_should_i_buy [2016/04/15 07:15] FDR [Devo8S] |
which_devo_tx_should_i_buy [2016/06/30 12:47] Arnold [Devo10] |
Line 41: | Line 41: | ||
Line 50: | Line 60: | ||
The Devo12 is the Rolls-Royce of Walkera radios. Compared to radios from other companies, I don't think you can beat it for the price, but it is also much more than most people will ever need in a transmitter. | The Devo12 is the Rolls-Royce of Walkera radios. Compared to radios from other companies, I don't think you can beat it for the price, but it is also much more than most people will ever need in a transmitter. |
which_devo_tx_should_i_buy.txt (15634 views) · Last modified: 2016/06/30 12:52 by Arnold
