which_devo_tx_should_i_buy
which_devo_tx_should_i_buy [2016/04/15 07:16] FDR [Devo10] |
Line 51: | Line 51: | ||
* **Cons:** | * **Cons:** | ||
* with 8 batteries, it is the heaviest Devo Tx | * with 8 batteries, it is the heaviest Devo Tx | ||
- | * I don't particularly like to button controls | + | * I don't particularly like the button controls |
* the menus are slower to navigate without a touch interface | * the menus are slower to navigate without a touch interface | ||
* it is not possible to convey information as quickly with the b/w screen | * it is not possible to convey information as quickly with the b/w screen | ||
Line 60: | Line 60: | ||
The Devo12 is the Rolls-Royce of Walkera radios. Compared to radios from other companies, I don't think you can beat it for the price, but it is also much more than most people will ever need in a transmitter. | The Devo12 is the Rolls-Royce of Walkera radios. Compared to radios from other companies, I don't think you can beat it for the price, but it is also much more than most people will ever need in a transmitter. | ||
Line 69: | Line 75: | ||
which_devo_tx_should_i_buy.1460729774.txt.gz (35006 views) · Last modified: 2016/04/15 07:16 by FDR
