which_devo_tx_should_i_buy
which_devo_tx_should_i_buy [2016/04/15 07:02] FDR [Devo7e] |
which_devo_tx_should_i_buy [2016/06/30 12:47] Arnold [Devo10] |
- | * **Pros:** \\ cheap \\ bright screen \\ small, light weight | + | * **Pros:** |
+ | * cheap | ||
+ | * bright screen | ||
- | * **Cons:** \\ only 7mW output power \\ only two 2-position switches \\ gimbals are inferior to its bigger brethren \\ limited memory means some features can't be supported (no multi-language support) \\ In my opinion, I would only buy a 7e if I was planning to primarily fly micro-helis, and wasn't big into lots of 3D trick flying. | + | * **Cons:** |
+ | In my opinion, I would only buy a 7e if I was planning to primarily fly micro-helis, and wasn't big into lots of 3D trick flying. | ||
==== Devo6s ==== | ==== Devo6s ==== | ||
Line 16: | Line 25: | ||
Line 31: | Line 41: | ||
+ | * **Cons:** | ||
- | == Cons == | ||
Line 49: | Line 60: | ||
which_devo_tx_should_i_buy.txt (7114 views) · Last modified: 2016/06/30 12:52 by Arnold
