which_devo_tx_should_i_buy
which_devo_tx_should_i_buy [2016/04/15 07:05] FDR [Devo7e] |
which_devo_tx_should_i_buy [2016/06/30 12:47] Arnold [Devo10] |
+ | * cheap | ||
+ | * bright screen | ||
Line 18: | Line 25: | ||
+ | * color touch screen | ||
Line 27: | Line 41: | ||
+ | * **Cons:** | ||
- | == Cons == | ||
Line 45: | Line 60: | ||
which_devo_tx_should_i_buy.txt (7253 views) · Last modified: 2016/06/30 12:52 by Arnold
