which_devo_tx_should_i_buy
which_devo_tx_should_i_buy [2016/04/15 07:13] FDR [Devo7e] |
Line 25: | Line 25: | ||
+ | * color touch screen | ||
Line 34: | Line 41: | ||
Line 43: | Line 60: | ||
The Devo12 is the Rolls-Royce of Walkera radios. Compared to radios from other companies, I don't think you can beat it for the price, but it is also much more than most people will ever need in a transmitter. | The Devo12 is the Rolls-Royce of Walkera radios. Compared to radios from other companies, I don't think you can beat it for the price, but it is also much more than most people will ever need in a transmitter. | ||
Line 52: | Line 75: | ||
which_devo_tx_should_i_buy.txt (6989 views) · Last modified: 2016/06/30 12:52 by Arnold
