which_devo_tx_should_i_buy
which_devo_tx_should_i_buy [2016/04/15 07:15] FDR [Devo8S] |
Line 41: | Line 41: | ||
Line 50: | Line 60: | ||
The Devo12 is the Rolls-Royce of Walkera radios. Compared to radios from other companies, I don't think you can beat it for the price, but it is also much more than most people will ever need in a transmitter. | The Devo12 is the Rolls-Royce of Walkera radios. Compared to radios from other companies, I don't think you can beat it for the price, but it is also much more than most people will ever need in a transmitter. | ||
Line 59: | Line 75: | ||
which_devo_tx_should_i_buy.1460729700.txt.gz (9926 views) · Last modified: 2016/04/15 07:15 by FDR
