which_devo_tx_should_i_buy
which_devo_tx_should_i_buy [2016/04/15 07:17] FDR [Devo12s] |
Line 51: | Line 51: | ||
* **Cons:** | * **Cons:** | ||
* with 8 batteries, it is the heaviest Devo Tx | * with 8 batteries, it is the heaviest Devo Tx | ||
- | * I don't particularly like to button controls | + | * I don't particularly like the button controls |
* the menus are slower to navigate without a touch interface | * the menus are slower to navigate without a touch interface | ||
* it is not possible to convey information as quickly with the b/w screen | * it is not possible to convey information as quickly with the b/w screen | ||
Line 75: | Line 75: | ||
which_devo_tx_should_i_buy.1460729833.txt.gz (9907 views) ยท Last modified: 2016/04/15 07:17 by FDR
