Delta wing question
No. It is just as I mentioned above. You reverse the output on channel 2. That won't show up on the main page, but will on the channel page. it has the effect of inverting the display of channel 1 on the channel page but not the main page, which causes the 'weird' behavior you are seeing.Hexperience wrote: Hmm. In the config I posted, on the main page, when I pull back on the elevator the first two bars go down as I expect them to. When I push right on Aileron the first bar goes down, second up, again as I expect.
In the monitor, pulling back on the Elevator makes the Ailerons work, side to side makes the Elevator work. Just as if ELE and AIL had been switched.
Maybe it's something to do with the fact that I'm using virtual channels?
You should likely not use a servo-reverse for a delta-wing config, as it will cause exactly this confusion
- Hexperience
For anyone who cares, my last post has a very simple delta wing config with no virtual channels. All the trims work as expected thanks to PB fixing the reverse trim issue.
Cheers!
- NotFastEnuf
- marcochiu
- stevecox
- Keep swinging
www.deviationtx.com/forum/model-template...ith-3-position-rates
Adelaide
- marcochiu
- marcochiu
- marcochiu
The "Trim"/"No Trim" is only shown if there is trim setup configured for that source. If you configure trims for a virtual channel, then the button would be shown on the complex mixer page of that virtual channel...
Even in case when all mixing implemented at one complex mix. Mux:mult multiply trim value.
- marcochiu
If you need change direction one of elevons, simply reverse this channel, at channel properties.
Safe value for Throttle channel will be better set to -100%. I don't know why it set to 0%.
- marcochiu
- Kenfacemire
Thankyou!
- Kenfacemire
- Kenfacemire
- N4JC
Hexperience wrote:
PhracturedBlue wrote:
Ahh. This is on purpose. The most common reason for using servo-reverse is thatthe servo doesn't move the direction you want it to (up is CW vs CCW). So on the main page, you don't want to see the reverse applied on the bar, since max-stick is still max-stick.Hexperience wrote: - The channel monitor on the main page does not invert the channel when reversed. Try this; normal elevator up and down-> both monitors show up and down. Revers the server setting. Channel monitor in the model page shows correctly, main page still shows up for up.
The channel page is really for debug, so you want to see what is actually being sent. So I apply the reverse there.
it must be the way I did my config... starting from scratch
If I do it without any virtual channels and only with mixes it behaves perfectly. Attached is a simple delta wing, very little config needed and the trims work correctly now (thanks PB)
A quick feedback, the model8.ini from Hexperience works for my new flying wing, looks simple and less complicated than others that uses virtual channel and such, maybe my need is simplier, so thanks for this.
All I needed was to reverse one of the channel to get one of the servo to go the correct direction.
Thanks again, this is great fun!
- badbob88
- Delta wing question
