- Removing shield and diode 7E for better reach
- aMax
Please keep in mind, he ripped off the upper pad ...Arakon wrote: The trace is protected, unless he scratched it up badly, there's no way it would have contact.
The trace underneath this bridge is one part of the PACTL line, which is the trace surrounding the oscillator connected to pin 30(GFSK modulator) on the RF chip.
Anyway..if there is no feedback from the user, we will never know.
- karl007
Unter the solder is a thin (not thin enought) copper core of a wire.
I took a MM and messured from my soldered short to another endpoint, so I get shure there are a connection (no cold solder). Right?
I would say, that my messurements told me that there are a connection and it should work. But please correct me.
A: 600 Ohm (displays 0.600 with MM setting 2kOhm)
B: 0.06 Ohm (displays 0.06 wit MM setting 200Ohm)
(add the MM setting, cause not 100% shure about the conversion)
Is there a indicator how i can verify if it works?
I tried without the shield in the lowest setting and get a range about 5-10cm.
What range should it be? 1m? 10m?
The last think I would try, is to resolder my short and tried with a isolated wire and only
solder the two ends, to exclude the possibility to short a trace below.
- aMax
...blue = measured points = 0 ohms
Attachment not found
- karl007
just to make shure i do it right
new bridge after remove my old solder?aMax wrote: ...yellow = new bridge
messure points after solder the new bridge, to check if it works?aMax wrote: ...blue = measured points = 0 ohms
- aMax
Yellow is the allowed bridge...., but if you are able, take the bottom pad of the removed diode.
Edit: You only will find one connection with 0 Ohms, I donĀ“t know to which pad the trace goes, but I think to the left.
Added a picture of the PACTL lines.
- karl007
aMax wrote: Please check blue first.... just to know, if there was a short or not.
Both pins got 0.6 Ohm.. So there is an unwanted short to the trace below, right?
- karl007
So the trace below are OK.
Then I add a wire along your yellow line and now it worked.
Thanks for being so patient and helpfull to me !!
Promise, I never solder smd anymore!
- aMax
What is your result now with range test at 100uW?
- Jerm357
When using the cyrf6936 module, at the lowest power of 100uw, the battery voltage was between 5.10 and 5.12 jumping back and forth. With the full power of 150mw, the voltage fluctuates between like 5.06 and 5.10. The A7105 module is unaffected and is acting the same as it was before the mod. This all make sense and I think is working like it should since Im asking more power from the cyrf6936 module now, but I just want to make sure this is happening to everyone who did the mod.
- aMax
At 100uW up to 30 mW, you will not notice it, no oscillating at my 7e,
The next difference is telemetry on/off at full power.
With Devo little less than with DSMX. Don't know why.......
- Jerm357
- mstrghettorigg
I'm pretty sure I didn't remove this and as far as I know it is a new unit.
I can't seem to get the range to increase. I left the diode on and jumpered the two side together.
I changed it to enable by taking the semicolong out of "has_pa-cyrf6936 = 1"
I did not take the semicolon out of "; enable-cyrf6936 = B12" (I tried both ways)
So I'm not sure if it's just the missing 10k that's causing the issue. Has anyone had an unit with missing resistors?
any help would be appreciated.
- mstrghettorigg
I tried taking it earlier and I couldn't zoom in enough, but i used a loupe and I got it hopefully good enough for you guys to see what's going on.
Please let me know if you have any ideas.
- mstrghettorigg
- mstrghettorigg
- mstrghettorigg
The resistance is reading 0 when I probe both side.
Other than that the image is pre modified. I'm sure it's probably very hard to see anything with that image though.
Please let me know if you have any ideas on what I can try.
- aMax
Have a look at ..PhracturedBlue wrote: What color was the device you removed and replaced with a jumper? may not be the proper solution. I ..........
www.deviationtx.com/forum/3-feedback-que...each?start=120#28384
...the reading is 12.2k at both directions.
I messured the removed part.
Edit: Don't care about the yellow square...., the part is right besides.
