DfuSe will not start up
16 Jun 2013 05:33 #11004 by birwin353
DfuSe will not start up was created by birwin353
title says it all. I am running win7 64. I downloaded and installed DfuSe 1.7 and 1.5 neither will boot up. I get the thinking "spinning ring" for like 20 seconds then it stops and nothing happens.
16 Jun 2013 09:18 #11010 by RandMental
Replied by RandMental on topic DfuSe will not start up
This has been discussed a few times on the forum, search the forum for further ideas.
However the conclusion to date seems to be the USB driver that is not loaded due to a clash with other USB devices on the PC.
Try removing all USB devices, de-install their drivers, boot clean, reinstall Dfuse and try running it again
16 Jun 2013 14:19 #11012 by birwin353
Replied by birwin353 on topic DfuSe will not start up
Thank you for a fast response. I just tried this and when I rebooted it loaded all my USB drivers back up again.
16 Jun 2013 17:15 #11013 by birwin353
Well I went in and deleted all my hidden usb drivers too rebooted, then reinstalled dfuse and it still is not starting up?? Anyone have any tips??
16 Jun 2013 17:54 #11014 by 944storm
Replied by 944storm on topic DfuSe will not start up
Unplug every USB device connected to the computer. Then start dfuse and connect the TX. That's the only way it works for me.
16 Jun 2013 19:18 #11016 by sbstnp
Replied by sbstnp on topic DfuSe will not start up
Check your PM.
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
17 Jun 2013 09:16 - 17 Jun 2013 09:23 #11047 by RandMental
birwin353 wrote: Thank you for a fast response. I just tried this and when I rebooted it loaded all my USB drivers back up again.
To prevent the reloading you have to unplug all the USB devices and only plug in the USB cable to the Devo TX.
Last edit: 17 Jun 2013 09:23 by RandMental.
17 Jun 2013 11:13 #11049 by birwin353
I am running on a laptop and have no devices pluged in, the ones that are reloading seem to be system drivers for the USB. I also loaded v1.4 which i am told should work but does not. I am at a loss
17 Jun 2013 11:25 #11050 by birwin353
On another note I can load and run the UP02 updater but I dont think that will help me. lol
17 Jun 2013 12:29 - 17 Jun 2013 13:10 #11053 by sbstnp
If you didn't already run DFuse with admin rights or in XP SP3 compatibility mode.
Edit: 1.4 is what I used to use. You don't need install it.
This is how I run mine:
Devo 10 + 4in1
Spektrum Dx9
Last edit: 17 Jun 2013 13:10 by sbstnp.
17 Jun 2013 13:23 #11056 by PhracturedBlue
Replied by PhracturedBlue on topic DfuSe will not start up
If you are desperate, you can install the Deviatiuon-Uploader i wrote. It does work in Windows, butis text only.
To use you need to getthe jar file here:
www.deviationtx.com/forum/7-development/...-testers-for-usbcode
Then install zadig.exe:
code.google.com/p/libusb-winusb-wip/down...etail?name=zadig.exe
Then plug in your tx in programing mode.
Then start zadig.exe (in admin mode) and select the STM32 device and install the driver
Now you can follow the instructions in the above post to install the dfu (works with both Deviation and Walkera's firmware)
You can rmeove the driver through the Device manager once installed.
17 Jun 2013 13:28 #11057 by birwin353
Thank you SBS but it also did not work! :( Im thinking that maybe I was not meant to have Devation on my controller :(
Phractured- thank you I may have to try it if nothing is working but it sounds a little in depth for my abilities, I could build yo anything but computers is my downfall lol
17 Jun 2013 14:18 #11062 by PhracturedBlue
I understand the confusion, snd if computers aren't your thing, I recommend holding off on installing my software. While it works, it isn't really ready for use on Windows machine due to the difficulty to install. If you come back in a couple of weeks, I should have something much easier to use.
19 Jun 2013 13:56 #11118 by birwin353
I think I will hav e better luck just trying to use another computer. I will have to sneak it on the wifes machine and try it out but it will be a few days cause Im going to the OBX for a few!! :)
Time to create page: 0.099 seconds
