Full house glider
25 Jan 2014 08:07 #19075 by kipecoul
Full house glider was created by kipecoul
Hello guys,
I just bought a devo 12s and i'm doing F3F.
I would like to know if anyone has already set a full house glider with V4.0.1?
I mean a glider with V or X tail, 2flap, 2aileron, butterfly brake, full span camber, snap-flap etc...
Best regards
Nicolas
25 Jan 2014 11:45 - 25 Jan 2014 11:48 #19080 by kreidler
Replied by kreidler on topic Full house glider
I did a small template some time ago. More or less for 'acro' purposes: http://deviationtx.com/forum/model-templates/2538-6ch-plane-predefined-mixer-template
Unfortunately we are limited to 10 virtual mixers which makes it necessary to do some mixing on the channels direct or renaming of unused mixers. Of course, full span camber, snap flap or flap offset is missing but could be realised easily. Only thing you have to care is the switch / pot knob assignment due to different Tx design.
For setup example all mixing done by complex templates:
AIL
- select source 'DiffL'
- add 'Spoileron'
Ch6 (for 2nd AIL)
- select 'DiffR'
- add 'Spoileron'
ELE
- select source 'ELE'
- add Spoileron-Flaperon-Compensation
Now you can adjust the spoiler in the virtual mixer without the need to change it for both ailerons separately. The compensation is performed by a 5 point curve. Do not forget to limit the maxima of the servos in advance.
Last edit: 25 Jan 2014 11:48 by kreidler.
25 Jan 2014 15:55 #19086 by kipecoul
Replied by kipecoul on topic Full house glider
The idea is to do something similar as :
rc-soar.com/opentx/setups/f3f/index.htm
With some change like using other switches than trim for snap flap and diff adjust.
Is it possible to reach this configuration?
best regards
Nicolas
17 Feb 2014 02:00 #20413 by Birdman
Replied by Birdman on topic Full house glider
I brought this subject up some time ago.
I said it then and will say it again now " i would not put deviation on a Devo12".
I think it is a step backwards for this type of model, even more so if you are not a programmer.
Interesting link.
Good luck
Bm
Time to create page: 0.025 seconds
