- jumper T8SG PLUS BIND frsky XM+ ACCST 2.1.2 FCC
- mj666
12 Jun 2021 05:49 #77449
by mj666
Replied by mj666 on topic jumper T8SG PLUS BIND frsky XM+ ACCST 2.1.2 FCC
Here is the remaining T8SG V2 build to try. As long your transmitter is working binding with any firmware XM+ receiver should work.
- v_nebe
- Topic Author
12 Jun 2021 08:12 #77450
by v_nebe
Replied by v_nebe on topic jumper T8SG PLUS BIND frsky XM+ ACCST 2.1.2 FCC
Да, я тоже пришёл к этому выводу. Купите приёмник frsky R-XR и будет вам счастье.
- mj666
12 Jun 2021 08:37 - 12 Jun 2021 08:55 #77451
by mj666
The PR with the fix has been merged. This fix should be available for all Deviation targets with the upcoming nightly builds. i'm using quite some XM/XM+ receivers with my Deo010 without any issues. They using various firmware versions and you always need to bind with the matching parameters.
Last edit: 12 Jun 2021 08:55 by mj666.
- Ale64
12 Jun 2021 12:08 #77452
by Ale64
Replied by Ale64 on topic jumper T8SG PLUS BIND frsky XM+ ACCST 2.1.2 FCC
Questa non oscurerà il mio display?
- mj666
12 Jun 2021 14:53 #77453
by mj666
In my understanding the T8SG Plus V3 should use the V2 software since it has an LCD screen and not an OLED. This is also what the web site is indicating.
www.jumper-rc.com/download/t8sg-plus-v3/
I dont have an T8SG myself but you can always flash back a working firmware if the actual firmware does not work. if you come from an older build you may also need to update the USB drive content (also part of the builds I send). You may backup the actual USB drive content to be save.
- Ale64
12 Jun 2021 17:43 #77454
by Ale64
Ottimo, ora funziona con questo aggiornamento.
Per il bind , come consigli di impostare la rc?
Perdonami ,sono un neofita di questo campo.
- mj666
12 Jun 2021 18:06 - 12 Jun 2021 18:06 #77455
by mj666
if you dont know what firmware your XM+ has installed you need to try all four possible combinations for "Format" and "Version" off the FrSkyX protocol.
FCC, V1
FCC, V2
EU, V1
EU, V2
All my XM+ came with V1 firmware and FCC or LBT (EU) is usually labeled at the packaging. You may also need to tune Freq-Fine in steps of +/-40 during bind if you have no success.
FCC, V1
FCC, V2
EU, V1
EU, V2
Last edit: 12 Jun 2021 18:06 by mj666.
- Ale64
13 Jun 2021 11:41 #77456
by Ale64
Evviva! Complimenti ora funziona tutto perfettamente , ho bindato la XM+ con FCC e V2.
Sono veramente felice, grazie infinite
- Ale64
08 Jan 2022 18:35 #77644
by Ale64
- Ale64
19 Jan 2022 20:53 #77733
by Ale64
chiedo scusa , ma avevo sbagliato l'aggiornamento , con lultima versione funziona
Time to create page: 0.077 seconds
- Home
