- jumper T8SG PLUS BIND frsky XM+ ACCST 2.1.2 FCC
- v_nebe
18 May 2021 15:29 #77389
by v_nebe
jumper T8SG PLUS BIND frsky XM+ ACCST 2.1.2 FCC was created by v_nebe
I can't bind the device data, which I just haven't tried.
Who bindil help what steps did you take??
Help!!!!!
Help!!!!!
- Ale64
11 Jun 2021 11:27 #77429
by Ale64
Replied by Ale64 on topic jumper T8SG PLUS BIND frsky XM+ ACCST 2.1.2 FCC
Anche io non riesco bindare frsky XM+ , potrebbe essere necessario flash EU ma non so proprio come si potrebbe risolvere, qualcuno ci può aiutare??
- mj666
11 Jun 2021 16:37 #77430
by mj666
Replied by mj666 on topic jumper T8SG PLUS BIND frsky XM+ ACCST 2.1.2 FCC
There is a update required to bind with the latest XM+ firmware 2.1.2. I have this working for the Devo10 and can do the related PR. The code is based on a update done for the MPM. For the moment you can downgrade the XM+ firmware to 2.1.0 to get it to work.
- mj666
11 Jun 2021 16:57 #77431
by mj666
- Ale64
11 Jun 2021 17:21 #77432
by Ale64
Scusate ma con la mia T8SG , come si potrebbe fare? Ci sono altri modi per aggiornare?
- mj666
11 Jun 2021 18:48 #77433
by mj666
@Ale64, @v_nebe here is the latest build for your transmitter including the fix. Please give it a try.
- v_nebe
11 Jun 2021 19:15 #77434
by v_nebe
Replied by v_nebe on topic jumper T8SG PLUS BIND frsky XM+ ACCST 2.1.2 FCC
I've never been able to put it all together. I ordered a frsky R-XR receiver, connected it without any problems. To connect the XM+, you need to flash it through taranis, and since I don't have that hardware, I've pushed the XM+ to the background.
- v_nebe
11 Jun 2021 19:17 #77435
by v_nebe
In addition to the firmware via taranis, I did not find another way. If anything succeeds, please write.
- Ale64
11 Jun 2021 19:28 #77437
by Ale64
Riassumendo, non si può fare! Giusto?
- mj666
11 Jun 2021 19:53 - 11 Jun 2021 19:54 #77438
by mj666
With the Deviation build above you should be able to bind the XM+ with any installed firmware. If you don't know what firmware is installed on the XM+ you need to try all 4 posible options in the worst case. One of this will bind.
Last edit: 11 Jun 2021 19:54 by mj666.
- Ale64
11 Jun 2021 21:20 #77439
by Ale64
Non funziona sulla mia radio, si oscura lo schermo. Allego foto
Attualmente ho istallato la V5.0.0-1c43d1b , allego modello
- v_nebe
11 Jun 2021 21:37 #77440
by v_nebe
This happened because the firmware was crooked. Most likely you made a mistake in choosing the file not for your equipment.
- v_nebe
11 Jun 2021 21:41 #77441
by v_nebe
Не пугайтесь. Проделйте все те же действия обновления прошивки, только для t8sg_v2-v5.0.0-c84450e
У меня была та же проблема.
- Ale64
11 Jun 2021 21:46 #77442
by Ale64
Forse V2 e V3 ci sono differenze
- v_nebe
11 Jun 2021 21:52 #77443
by v_nebe
На сайте jumper стандартная прошивка идёт v2.
www.jumper-rc.com/download/t8sg-plus-v3/
- v_nebe
11 Jun 2021 21:54 #77444
by v_nebe
У меня такая же аппаратура. Неделю пытался соединить t8sg с xm+. Перепробовал все способы. Даже open tx пытался вшить, без успешно.
- Ale64
11 Jun 2021 22:05 #77445
by Ale64
L'ho buttata nella spazzatura
- v_nebe
11 Jun 2021 22:07 #77446
by v_nebe
Оставьте приёмник с него можно взять антены как минимум
- v_nebe
11 Jun 2021 22:10 #77447
by v_nebe
Название аппаратуры v3 скорее всего из за дизайна. А программное обеспечение v2. Как я понял все необходимые модули в этой аппаратуре есть. Дело в ошибках в прошивке.
- Ale64
11 Jun 2021 22:23 - 11 Jun 2021 22:25 #77448
by Ale64
Ok capito. Altra informazione: lo slot per microSD, a che serve? Forse era meglio comprare la T12 con openTX
Last edit: 11 Jun 2021 22:25 by Ale64.
Time to create page: 0.166 seconds
