- Tarot ZYX-S issue using satellite receiver
He said the Tarot looses binding and only the aileron and elevator channels are operating (after reseting). He tried with Spektrum and Tarot satellite receivers, but neither works.
If he ties the Tarot to the channel outputs of an AR7000, then it works.
He used that model with a DX7 before...
Has anybody tried to use a satellite receiver with deviation?
If you have one, please try will it bind with a simple satellite receiver!
- Eriskio
Could be an idea to try a satellite on my helis. Which satellite model can be preferred to test? there are compatible satellite (like orange)?
- Wene001
ZYX-S is working with DSM-2 Sat and DX8 as expected in DSM2-2 Mode
(Sat prebound with Orange 6CH on DX8)
When i bind my DSM-2 Sat (on Orange 6CH) with Devo 8 i canĀ“t ge it work with the ZYX-S.
Only the aileron and elevator channels are visible in ZYX-S PC Software in DSM2-2 Mode.
Tried all the other modes on ZYX-S Software without success.
My Satllite lights solid after binding.
If i turn TX und Rx off and on, the Led is blinking (like it would do after a brownout).
@Eriskio
Original Spektrum DSMX
Original Spektrum DSM2
and
Orange DSM2 Sat
works with ZYX-S and DX8 for me.
All prebound and used in ZYX Mode DSM2-2
Cheers Werner
Same results, that my friend got...
- Eriskio
Wene001 wrote: My Satllite lights solid after binding.
Today I tested two Orange RX. Same effect: the red led is solid after binding, but after the first OFF and ON of both (TX and RX) the start blinking slowly (as per power fault problem).
It seems to be because the session ID (part of ID binding code?) is always the same.
Bye Paolo.
- coaster
cheers
Graziano
- Bubu38
- digitracer
Since I'm thinking of getting a zyx-s myself, too I would be very interested if someone could confirm this methode working.
- Wene001
not working with Deviation.
1) bind Rx with satellite,
2) detach antenna from Rx PCB,
3) place Tx in the distance from Rx (or at range test mode) to switch off LED in Rx, LED in satellite should be solid (or blinking slowly?),
4) test all 7 channels,
5) reboot Rx,
6) test all 7 channels.
It sounds like the tarot expects very specific channel outputs, and that the Satellite is binding properly. Has anyone played with different swash settings in Deviation? I don't know how to reconcile that 2 channels work and the others don't in this configuration.
- Wene001
It seems like the satellite is using an other protocol after binding with deviation ?!?
With Dx 8 6channel at neutral is no problem for the zyx.
Greetings Werner
www.rcgroups.com/forums/showpost.php?p=22829894&postcount=5239
Yeah, but I'm not going to spend $150 on a Tx that I'll use for all of 1 day.vlad_vy wrote: Tarot can bind with a DX6i.
However there is one thing:
I don't know in which "Modulation Type" our samples are...1.- Make sure in DX6i Modulation Type is set as "AUTO DSM-X ENABLE DSMX AND DSM-2 STANDAR RECEIVERS".
