- Tarot ZYX-S issue using satellite receiver
05 Oct 2012 08:27 - 05 Oct 2012 10:34 #2001
Tarot ZYX-S issue using satellite receiver was created by FDR
My friend recently installed deviation and tried to configure it to a FBL heli using the Tarot ZYX-S fbl controller with a satellite DSM2 receiver.
He said the Tarot looses binding and only the aileron and elevator channels are operating (after reseting). He tried with Spektrum and Tarot satellite receivers, but neither works.
If he ties the Tarot to the channel outputs of an AR7000, then it works.
He used that model with a DX7 before...
Has anybody tried to use a satellite receiver with deviation?
Last edit: 05 Oct 2012 10:34 by FDR. Reason: typo
05 Oct 2012 10:19 - 05 Oct 2012 10:36 #2002
Replied by vlad_vy on topic Tarot ZYX-S issue using satellite reveiver
Last edit: 05 Oct 2012 10:36 by vlad_vy.
05 Oct 2012 12:45 #2004
Replied by FDR on topic Tarot ZYX-S issue using satellite reveiver
Thanks, but neither DSM2 type worked...
15 Oct 2012 14:34 #2253
Replied by FDR on topic Tarot ZYX-S issue using satellite receiver
Does anybody use the Tarot ZYX-S?
If you have one, please try will it bind with a simple satellite receiver!
- Eriskio
15 Oct 2012 17:30 #2266
by Eriskio
Replied by Eriskio on topic Tarot ZYX-S issue using satellite receiver
I have 4 Tarot ZXY "S", but no DSM2 satellite for the moment.
Could be an idea to try a satellite on my helis. Which satellite model can be preferred to test? there are compatible satellite (like orange)?
15 Oct 2012 18:26 #2273
I think my friend have both a Spektrum and a Tarot one, but neither worked...
- Wene001
17 Oct 2012 08:59 #2297
by Wene001
Replied by Wene001 on topic Tarot ZYX-S issue using satellite receiver
Hello FDR
ZYX-S is working with DSM-2 Sat and DX8 as expected in DSM2-2 Mode
(Sat prebound with Orange 6CH on DX8)
When i bind my DSM-2 Sat (on Orange 6CH) with Devo 8 i can´t ge it work with the ZYX-S.
Only the aileron and elevator channels are visible in ZYX-S PC Software in DSM2-2 Mode.
Tried all the other modes on ZYX-S Software without success.
My Satllite lights solid after binding.
If i turn TX und Rx off and on, the Led is blinking (like it would do after a brownout).
@Eriskio
Original Spektrum DSMX
Original Spektrum DSM2
and
Orange DSM2 Sat
works with ZYX-S and DX8 for me.
All prebound and used in ZYX Mode DSM2-2
Cheers Werner
@Eriskio
and
Orange DSM2 Sat
Cheers Werner
17 Oct 2012 09:06 #2298
Same results, that my friend got...
- Eriskio
19 Oct 2012 17:15 #2336
by Eriskio
Today I tested two Orange RX. Same effect: the red led is solid after binding, but after the first OFF and ON of both (TX and RX) the start blinking slowly (as per power fault problem).
It seems to be because the session ID (part of ID binding code?) is always the same.
Bye Paolo.
Wene001 wrote: My Satllite lights solid after binding.
Bye Paolo.
- coaster
19 Oct 2012 17:50 #2341
by coaster
Replied by coaster on topic Tarot ZYX-S issue using satellite receiver
same for me testet with spektrun ar6200 an orange, regardless of attached flybarless or no. First binding the led is solid and after off/on the led start blinking.
cheers
Graziano
cheers
Graziano
- Bubu38
19 Oct 2012 20:11 - 18 Nov 2012 19:53 #2343
by Bubu38
Replied by Bubu38 on topic Tarot ZYX-S issue using satellite receiver
Same thing for me with an Orange sat / ZYX-s Yellow led blinks on each setup in ZYX-s software...It's bound correctly but gyro turns in RX signal error every time...
Last edit: 18 Nov 2012 19:53 by Bubu38.
- digitracer
23 Oct 2012 07:04 #2385
by digitracer
Replied by digitracer on topic Tarot ZYX-S issue using satellite receiver
According to a thread on helifreak (
www.helifreak.com/archive/index.php/t-427172.html
) one should bind the R100 connected to an Orange receiver before connecting it to the zyx-s first time.
Since I'm thinking of getting a zyx-s myself, too I would be very interested if someone could confirm this methode working.
- Wene001
23 Oct 2012 07:29 - 23 Oct 2012 07:30 #2386
by Wene001
This methode is working for me with DX8
not working with Deviation.
Last edit: 23 Oct 2012 07:30 by Wene001.
23 Oct 2012 10:48 - 23 Oct 2012 11:06 #2387
Replied by vlad_vy on topic Tarot ZYX-S issue using satellite receiver
For clarity, will be interesting to test the satellite separately, with suppressed Rx. You need for test Rx with long detachable antenna.
1) bind Rx with satellite,
2) detach antenna from Rx PCB,
3) place Tx in the distance from Rx (or at range test mode) to switch off LED in Rx, LED in satellite should be solid (or blinking slowly?),
4) test all 7 channels,
5) reboot Rx,
6) test all 7 channels.
5) reboot Rx,
Last edit: 23 Oct 2012 11:06 by vlad_vy.
24 Oct 2012 19:03 #2402
Replied by PhracturedBlue on topic Tarot ZYX-S issue using satellite receiver
The brownout issue is likely unrelated to the tarot issue. you can get around it by turning on the Rx before the tx.
It sounds like the tarot expects very specific channel outputs, and that the Satellite is binding properly. Has anyone played with different swash settings in Deviation? I don't know how to reconcile that 2 channels work and the others don't in this configuration.
- Wene001
24 Oct 2012 21:30 - 24 Oct 2012 21:31 #2406
by Wene001
Zyx-s is waiting for 6 clean Channels. No Tx Side swash mix is required.
It seems like the satellite is using an other protocol after binding with deviation ?!?
With Dx 8 6channel at neutral is no problem for the zyx.
Greetings Werner
Greetings Werner
Last edit: 24 Oct 2012 21:31 by Wene001.
25 Oct 2012 00:41 #2407
I don't have a dx8. The signal I send is indistinguishable from what my hp6dsm sends (I just ordered a very cool USRP SDR, so I'll verify that when it comes in). So I have no idea which magic piece is missing, nor do I have any way to identify that missing piece. If a Tarot will bind with a DX5e, then I'll probably get one, since I want to work on DSM-X stuff, but my guess is it won't (since it needs 6 channels).
25 Oct 2012 07:46 #2418
Tarot can bind with a DX6i.
www.rcgroups.com/forums/showpost.php?p=22829894&postcount=5239
25 Oct 2012 11:28 #2419
Yeah, but I'm not going to spend $150 on a Tx that I'll use for all of 1 day.vlad_vy wrote: Tarot can bind with a DX6i.
25 Oct 2012 11:34 #2420
Of course not, but that solution is interesting in a way, that deviation's DSM2 implementation is based on DX6i samples, so it should behave like one.
However there is one thing:
I don't know in which "Modulation Type" our samples are...1.- Make sure in DX6i Modulation Type is set as "AUTO DSM-X ENABLE DSMX AND DSM-2 STANDAR RECEIVERS".
Time to create page: 0.290 seconds
