Devo 8s Deviation with phoenix sim v4.0
08 Mar 2013 02:08 #7505 by EVERNIN
Hi, just upgrade my devo 8s to Deviation and just installed phoenix sim v4.0 to my pc, have been trying to use my devo tx with sim but it does not recognize it, using windows 7 64bit, have tried directly with phoenix interface(dongle) to my Devo and also using a stereo to mono adapter with no success,any help will be grateful.
one more question, how do I know if my Devo 8s is either 100mw or 10mw???
sorry I am a beginner.
Thank you.
Ever
08 Mar 2013 02:43 #7509 by shadow
Replied by shadow on topic Devo 8s Deviation with phoenix sim v4.0
You need to select ppm as the protocol
I attached the ini file I use for the sim.
08 Mar 2013 05:29 #7516 by FDR
Replied by FDR on topic Devo 8s Deviation with phoenix sim v4.0
With deviation it will be definitely a 100mW one, because that limitation was in the fw...
  • rbe2012
  • rbe2012's Avatar
08 Mar 2013 07:10 #7518 by rbe2012
Replied by rbe2012 on topic Devo 8s Deviation with phoenix sim v4.0
Ever,
if you use a nightly build the PPM output may be used for debiggung informations so it will not be available for a sim.
Use the last official version (2.1.1) instead.
08 Mar 2013 08:10 #7519 by Joshua
Replied by Joshua on topic Devo 8s Deviation with phoenix sim v4.0
nightly build's works fine for me with phoenix sim v4.0.
ciao, Bernd
08 Mar 2013 12:00 #7522 by Hexperience
Replied by Hexperience on topic Devo 8s Deviation with phoenix sim v4.0
10 Mar 2013 02:04 #7574 by EVERNIN
Replied by EVERNIN on topic Devo 8s Deviation with phoenix sim v4.0
Thank you all of you, Now I am using my Devo 8s/Deviation with Phoenix v4.0n,
Shadow,using your model8.ini file, thaknks, will be asking for mor support since I am a beginner.
10 Mar 2013 05:51 #7585 by shadow
No Problem Enjoy.
27 May 2014 03:50 #23652 by pypass
Replied by pypass on topic Devo 8s Deviation with phoenix sim v4.0
Easy to set...just go to protocol choice and check ppm
Time to create page: 0.581 seconds
