CX-10 (blue board) and DEVO 7E Deviation
- Maco33
I would like to ask how to update the firmware? ( www.deviationtx.com/downloads-new/catego...-10a-blue-board-cx11 ). After the upgrade is a "model setup" empty display
M.
- Deal57
Most of your questions should be answered there, and if you have more, please let us know!
- Maco33
Thank You.
- Deal57
I recommend using the nightly build unless you need to test a new feature. Test builds are intended for use by experienced testers and may not perform correctly, so you need to be more careful about their use (I suggest removing any blades, rotors or other moving parts before operating them!).
- Maco33
M.
- Deal57
If you use a test build, you will get only the DFU file and the protocol folder, and you need to install it after installing the nightly it was built from
You can't use a test build with 4.0.1 release. You MUST use the nightly build.
- Maco33
- Maco33
I have nrf24l01 module to the transmitter connected.
This is not question just for Deal57
M.
- huge
i am also interested in flying the cx-10 with blue board,
i found this so far
www.deviationtx.com/downloads-new/catego...10a-blue-board-cx11#
so what i understand is, i need to flash a nightly build *.dfu with dfuse, and when i am done i need to flash the *.dfu of the test build? and afterwards copy the protocol folder of the test build with a usb connection?
sorry for the question but i just got a devo 7e,
Regards
- Thomas.Heiss
Your test-build link is quite old from May 2015!
bitbucket.org/deviationtx/deviation/commits/all?search=cx10
goebish 51df623 Add Cheerson CX-10A (blue board) protocol Branches CX10A 2015-05-26
PhracturedBlue ef56c9a M Merged in goebish/deviationtx/CX10A (pull request #71) Add Cheerson CX-10A / CX-11 and DM007 protocol 2015-05-30
Try the "Blue-A" option when you selected the protocol.
The DFU does NOT contain the file system and ini files.
No, IMHO you only flash the firmware DFU file once, not twice.
So you would have to use the file system files from the nightly-build firmware ZIP file and the test-build DFU.
BUT....in this case just try the latest offical nightly-build ZIP which includes DFU and all files for file system INCLUDING protocol folder.
You really have to copy over the protocol files for the Devo 7E which correlate to the DFU from same ZIP file.
Thomas
- ursus69
Maco33 wrote: Still, I went back to the first part of the query, is there any possibility to control quadrocopters CX-10 blue board using DEVO7E Deviation?
M.
Yes! You can control it without problems!! I do it with my Devo7E & my CX10A & CXstars..
You need to use a nightly build...
If you need the .ini, tell us..
- huge
Regards
- ursus69
The nightly build have the protocols to control the CX10... The Deviation 4.0.1 don't have the CX10 blue board protocol...
When I get home, I tell you my deviation version and I will attach the cx10 config!
- ursus69
Fmode--> flips
SW B--> Mode0 (easy) Mode1 (hard) Mode2 (headless)
Deviation V4.0.1-dfa9397 (nightly build)
Hope this help you!
- Maco33
M.
- ursus69
- huge
a motor of my cx-10 died, but replaced it and its working now!
regards
- Jj30
what protocol should I be using for the cx10A thank you
- Jj30
- Jj30
- CX-10 (blue board) and DEVO 7E Deviation
