CX-10 (blue board) and DEVO 7E Deviation
05 Feb 2016 11:57 #42625 by Maco33
Hi, I would like to fly with the CX-10 blue plate and DEVO7e (I nRF24L01 module installed). What must I do for it? I read a lot of pages, but I'm really confused. Please write simply what exactly I have to do. Thank you very much and sorry for bad English. I'm from czech rep.
I would like to ask how to update the firmware? ( www.deviationtx.com/downloads-new/catego...-10a-blue-board-cx11 ). After the upgrade is a "model setup" empty display :-(
M.
05 Feb 2016 22:17 #42645 by Deal57
Replied by Deal57 on topic CX-10 (blue board) and DEVO 7E Deviation
Welcome! Deviation is an amazing transmitter, and like any other high-function tool, it may take some time to absorb. Did you review the User Manual for your transmitter (see the list on the left side of the web page)? Essentially it will walk you through downloading the files from the web and loading them into your deviation transmitter. There is a lot of technical material there, too, so if you feel you're in too deep, I suggest you look at the forum section called Tutorials .
Most of your questions should be answered there, and if you have more, please let us know!
06 Feb 2016 11:36 #42661 by Maco33
Replied by Maco33 on topic CX-10 (blue board) and DEVO 7E Deviation
Hello, thank you for your response. Transmitter DEVO 7e I already own half of the year and the first thing I did was to change firmware to 4.0.1 DEVIATION, it was no problem. However, deviation-Devo7e-v4.0.1-8b9e2a0 firmware upgrade does not have a standard file system, there is only the folder "protocols". I tried different installation options and failed. Then I searched the net for help, but I found only this: www.deviationtx.com/forum/builds/3607-de...with-empty-main-menu . That is not clear to me how to install the firmware. I need to know how to (step by step) to install this firmware pleas.
Thank You.
06 Feb 2016 13:22 #42666 by Deal57
The "nightly" build is a full compilation of the Deviation software with the newest bug fixes and features, and includes all the file system and folders. If you use a test build, you will get only the DFU file and the protocol folder, and you need to install it after installing the nightly it was built from; essentially you load the DFU then copy the protocol folder over the old one without removing any of the rest of the file system.
I recommend using the nightly build unless you need to test a new feature. Test builds are intended for use by experienced testers and may not perform correctly, so you need to be more careful about their use (I suggest removing any blades, rotors or other moving parts before operating them!).
06 Feb 2016 14:41 #42670 by Maco33
Hello, thank you for your answer. I did everything according to your recommendations, but I failed :-( With DfuSe USB Upgrade Tool again I uploaded firmware 4.0.1, after formatting the flash memory I copied the files, everything was OK. Then I again via USB Upgrade Tool DfuSe recorded new firmware (Devo7e-v4.0.1-8b9e2a0) and copied the other firmware folder "protocol". After switching on the transmitter startup image on the display display so that the firmware version is displayed at the bottom so that there was hardly visible. I squeezed ent and empty again Main menu item (see illustration below). :-(
M.
06 Feb 2016 14:46 #42672 by Deal57
You can't use a test build with 4.0.1 release. You MUST use the nightly build.
07 Feb 2016 10:32 #42716 by Maco33
Yes, now I understand it and everything works great. Once again, many thanks for your help. M.
07 Feb 2016 10:49 #42718 by Maco33
Still, I went back to the first part of the query, is there any possibility to control quadrocopters CX-10 blue board using DEVO7E Deviation?
I have nrf24l01 module to the transmitter connected.
This is not question just for Deal57 ;)
M.
16 Feb 2016 18:28 #43189 by huge
Replied by huge on topic CX-10 (blue board) and DEVO 7E Deviation
i am also interested in flying the cx-10 with blue board,
i found this so far
www.deviationtx.com/downloads-new/catego...10a-blue-board-cx11#
so what i understand is, i need to flash a nightly build *.dfu with dfuse, and when i am done i need to flash the *.dfu of the test build? and afterwards copy the protocol folder of the test build with a usb connection?
sorry for the question but i just got a devo 7e,
Regards
17 Feb 2016 12:13 - 17 Feb 2016 12:18 #43199 by Thomas.Heiss
Replied by Thomas.Heiss on topic CX-10 (blue board) and DEVO 7E Deviation
I do not own the CX-10 but I believe Goebish test-build already made it into nightly-build source repository.
Your test-build link is quite old from May 2015!
bitbucket.org/deviationtx/deviation/commits/all?search=cx10
goebish 51df623 Add Cheerson CX-10A (blue board) protocol Branches CX10A 2015-05-26
PhracturedBlue ef56c9a M Merged in goebish/deviationtx/CX10A (pull request #71) Add Cheerson CX-10A / CX-11 and DM007 protocol 2015-05-30
Try the "Blue-A" option when you selected the protocol.
The DFU does NOT contain the file system and ini files.
No, IMHO you only flash the firmware DFU file once, not twice.
So you would have to use the file system files from the nightly-build firmware ZIP file and the test-build DFU.
BUT....in this case just try the latest offical nightly-build ZIP which includes DFU and all files for file system INCLUDING protocol folder.
You really have to copy over the protocol files for the Devo 7E which correlate to the DFU from same ZIP file.
Thomas
Last edit: 17 Feb 2016 12:18 by Thomas.Heiss.
18 Feb 2016 07:46 #43229 by ursus69
Replied by ursus69 on topic CX-10 (blue board) and DEVO 7E Deviation
Maco33 wrote: Still, I went back to the first part of the query, is there any possibility to control quadrocopters CX-10 blue board using DEVO7E Deviation?
M.
Yes! You can control it without problems!! I do it with my Devo7E & my CX10A & CXstars..
You need to use a nightly build...
If you need the .ini, tell us..
18 Feb 2016 08:22 #43230 by huge
Yes please, would be great. What do the. Ini files contain besides the hardware config?
Regards
18 Feb 2016 08:46 #43233 by ursus69
The .ini file is for the configuration model! ( www.deviationtx.com/forum/model-configs )
The nightly build have the protocols to control the CX10... The Deviation 4.0.1 don't have the CX10 blue board protocol...
When I get home, I tell you my deviation version and I will attach the cx10 config!
18 Feb 2016 19:58 #43251 by ursus69
I attach the CX10A.ini!
Fmode--> flips
SW B--> Mode0 (easy) Mode1 (hard) Mode2 (headless)
Deviation V4.0.1-dfa9397 (nightly build)
Hope this help you!
20 Feb 2016 21:40 #43382 by Maco33
Super, it works :woohoo: Big thanks ursus69! I am very happy :)
M.
22 Feb 2016 08:17 #43450 by ursus69
Cool! ;) Enjoy it!
29 Feb 2016 20:48 #43909 by huge
hey thanks,
a motor of my cx-10 died, but replaced it and its working now!
regards
29 Mar 2016 22:23 #45407 by Jj30
Replied by Jj30 on topic CX-10 (blue board) and DEVO 7E Deviation
hi I know this is an old post, I hope you see it, I have devo 7E modded I can bind my cx10 but cant seem to bind my cx10A
what protocol should I be using for the cx10A thank you
29 Mar 2016 22:24 #45408 by Jj30
ok I just read the blue board protocol, ill try that
29 Mar 2016 22:27 #45409 by Jj30
got it flyin awesome!
Time to create page: 0.137 seconds
