Cleanflight Configuration: Max is limited at 1860
28 Oct 2016 16:40 - 28 Oct 2016 16:42 #55478 by CesiumSalami
Setup: Devo 7e. Deviation 5.0. DasMikro DSM2 Receiver. Cleanflight/SPRACINGF3 1.13.0 (brushed)
I *am* new to this but am running into an issue where regardless of the +/- Scalar or Min/Max I simply can't break past a throttle input of 1860 and I'm trying to hit the 1000-2000 range with 1500 being the middle.
I've fiddled around with Min/Max and Scalar and can't go ~ 975 or above ~1860. As a result, I've just set it up so that the range is roughly 1000-1860 with a mid point of 1436 (I'll revise that to 1430 shortly.) I've used the subtrim to get the mid point to 1436 (again gotta fix to 1430)
Two questions:
  1. Using this method do you think I'll be able to access the full range i.e. Max Power?
  2. Am I making a bone head move and missing some really obvious stuff here?
Picture of some settings attached.
Note: I adjusted the "MaxThrottle" and "Stick Max" to 1860 AFTER I realized I couldn't hit 2000. When it's set at 2000 I still can't get "2000"
Last edit: 28 Oct 2016 16:42 by CesiumSalami. Reason: Nits and Picks
28 Oct 2016 17:12 - 28 Oct 2016 17:13 #55480 by aMax
May be your receiver is the limitation. If the firmware does it not set correctly, these are the limits. Try to seach a forum for "DasMikro".
Did you already update the firmware?
Last edit: 28 Oct 2016 17:13 by aMax.
28 Oct 2016 17:14 #55481 by CesiumSalami
Replied by CesiumSalami on topic Cleanflight Configuration: Max is limited at 1860
Oh! I didn't know that was also a potential issue! I haven't done down that path yet - but I will now. Thanks.
I'll post back if it leads anywhere.
Thanks thanks thanks!
28 Oct 2016 17:16 - 28 Oct 2016 19:21 #55482 by aMax
If you used the scale and subtrim function on the the Devo, this is what`s leftover....sorry.
Last edit: 28 Oct 2016 19:21 by aMax. Reason: typo ...need better glasses
28 Oct 2016 17:52 #55485 by hexfet
Have you done a stick calibration on the 7e?
28 Oct 2016 19:33 - 28 Oct 2016 19:35 #55488 by aMax
This is a known issue.
Read the comments under "shalersrs" review. / three points
www.banggood.com/DSM2-5CH-2_4Ghz-RC-Micr...d=320630809307675004
Last edit: 28 Oct 2016 19:35 by aMax.
28 Oct 2016 20:29 #55490 by CesiumSalami
hexfet wrote: Have you done a stick calibration on the 7e?
Yessir, I have - thank you for checking though and for the suggestion! Definitely something I could've overlooked B)
28 Oct 2016 20:34 #55491 by CesiumSalami
aMax wrote: This is a known issue.
You sir! Are amazing. Thank you very much!
I've got a little homework ahead of me - but I have a number of options here it looks like.
My apologies for not catching this from the banggood review!
Just for the benefit of others that might happen upon this here's some of the options that the banggood review mentioned:
it wouldnt read the full range of my sticks in clean flight . i switched to a spektrum 6100 and the issue went away.
Just use Cleanflight\'s rxrange command to correct this. There is nothing wrong with the receiver.
29 Oct 2016 21:57 #55509 by CesiumSalami
FYI - The CLI rxrange command was just the ticket. Thanks for guiding me in that direction aMax!
One thing that I did notice is that Cleanflight's channels appear to start at 0 whereas Deviation's start at 1.
So, by running the command below you would be modifying Channel 1:
rxrange 0 975 1860
The sytanx for the command is:
rxrange <channel> <min> <max>
Don't forget to
save
31 Oct 2016 18:28 #55565 by mike_j
Nice to see that my little comment on Banggood about using the rxrange command is helping people. :)
02 Nov 2016 14:01 #55611 by CesiumSalami
I say this genuinely: This stuff is crazy, right? I can't tell if this community is really small or everybody involved is just ready to google the hell out of the internet to find the answers .... It's all just so interconnected. You see the same people pop up everywhere lending a hand.
I'm floored by the collaborative nature of this hobby.
Thanks so much for leaving that comment, and aMax for pointing it out - shame on me for not finding it first :)
02 Nov 2016 16:31 #55621 by aMax
Hope you tried RCGroups first, there is the family..... and mostly the source of all that stuff.
02 Nov 2016 18:27 #55623 by CesiumSalami
Yep! Yep! That was the forum that led me to the Devo 7e and to here. Thanks for the tip though!
Time to create page: 0.037 seconds
