Elrs 2.4 ghz ES24TX pro upgrade
- Fedebhrkz
- Topic Author
19 May 2022 16:55 #77993
by Fedebhrkz
Elrs 2.4 ghz ES24TX pro upgrade was created by Fedebhrkz
good evening guys, does anyone have the elrs module on a t8sg plus v3? I can't get it to work / see the data on the radio (hardware crsf modification on the radio already done and last firmware installed) now crsf appears on the display but if I click on it it goes to a menu without writing, only black ... the module is turns on and seems to work because the rgb leds change behind
19 May 2022 20:32 #77994
Replied by hexfet on topic Elrs 2.4 ghz ES24TX pro upgrade
Do you have the UART_INVERTED option un-checked in the ELRS firmware? The default setting is checked.
- Fedebhrkz
- Topic Author
22 May 2022 12:56 #77997
by Fedebhrkz
Replied by Fedebhrkz on topic Elrs 2.4 ghz ES24TX pro upgrade
Yess… inverted, like in Elrs descriprion,no flag but it doesn’t work. In crsf menu no words
- FlyturboKwad
05 Jun 2022 11:21 - 05 Jun 2022 11:30 #78001
by FlyturboKwad
Replied by FlyturboKwad on topic Elrs 2.4 ghz ES24TX pro upgrade
It works, I have tried it but I get random signal loss. You need to flash your TX module with UART_INVERTED option un-checked. I have full ELRS menus as well. Also, have you done the crossfire hardware MOD?
Last edit: 05 Jun 2022 11:30 by FlyturboKwad.
- Fedebhrkz
- Topic Author
05 Jun 2022 16:27 #78002
by Fedebhrkz
Modd crossfire fatta,ho provato anche diversi firmware, ma la mia radio è la V3 Carbon con display lcd,tutti i firmware che fanno vedere i parametri sono per la V2 OLED
- FlyturboKwad
05 Jun 2022 18:49 #78003
by FlyturboKwad
Hai l'ultima versione di Deviation? Inoltre, non è importante avere la visualizzazione dello schermo sul T8SG, puoi eseguire tutte le impostazioni con il modulo ELRS TX.
- Fedebhrkz
- Topic Author
05 Jun 2022 18:53 #78004
by Fedebhrkz
Penso di sì, se non l’ultima quella prima. Ma come faccio il bind senza avere un display? Ho l’happymodel tx pro e non ha un display
- Home
- General
- General Discussions
- Elrs 2.4 ghz ES24TX pro upgrade
