Elrs 2.4 ghz ES24TX pro upgrade
19 May 2022 16:55 #77993 by Fedebhrkz
Elrs 2.4 ghz ES24TX pro upgrade was created by Fedebhrkz
good evening guys, does anyone have the elrs module on a t8sg plus v3? I can't get it to work / see the data on the radio (hardware crsf modification on the radio already done and last firmware installed) now crsf appears on the display but if I click on it it goes to a menu without writing, only black ... the module is turns on and seems to work because the rgb leds change behind
19 May 2022 20:32 #77994 by hexfet
Replied by hexfet on topic Elrs 2.4 ghz ES24TX pro upgrade
Do you have the UART_INVERTED option un-checked in the ELRS firmware? The default setting is checked.
22 May 2022 12:56 #77997 by Fedebhrkz
Replied by Fedebhrkz on topic Elrs 2.4 ghz ES24TX pro upgrade
Yess… inverted, like in Elrs descriprion,no flag but it doesn’t work. In crsf menu no words
05 Jun 2022 11:21 - 05 Jun 2022 11:30 #78001 by FlyturboKwad
Replied by FlyturboKwad on topic Elrs 2.4 ghz ES24TX pro upgrade
It works, I have tried it but I get random signal loss. You need to flash your TX module with UART_INVERTED option un-checked. I have full ELRS menus as well. Also, have you done the crossfire hardware MOD?
Last edit: 05 Jun 2022 11:30 by FlyturboKwad.
05 Jun 2022 16:27 #78002 by Fedebhrkz
Modd crossfire fatta,ho provato anche diversi firmware, ma la mia radio è la V3 Carbon con display lcd,tutti i firmware che fanno vedere i parametri sono per la V2 OLED
05 Jun 2022 18:49 #78003 by FlyturboKwad
Hai l'ultima versione di Deviation? Inoltre, non è importante avere la visualizzazione dello schermo sul T8SG, puoi eseguire tutte le impostazioni con il modulo ELRS TX.
05 Jun 2022 18:53 #78004 by Fedebhrkz
Penso di sì, se non l’ultima quella prima. Ma come faccio il bind senza avere un display? Ho l’happymodel tx pro e non ha un display
Time to create page: 0.109 seconds
