Radiolink AT9 as a platform for Deviation?
- Topic Author
At first glance:
MCU STM32F103VET6
RF module (bus = SPI)
CC2533F96 96-KB Flash, 6-KB RAM
RFX2401C
chip 8 pin = unknown
quartz 32.000 Mhz
- victzh
- Topic Author
- victzh
- Topic Author
1) MCU: STM32F103VET6
2) quartz: 8.000 Mhz
3) 128K-bit SPI SERIAL ELECTRICALLY ERASABLE PROM: IS25C128A-2GLI
4) DC-DC converter: MC34063A
5) LCD Display: FPC-SJ28N-19VOF
- victzh
What's discouraging is the amount of flash - only 16KBytes of serial flash. How large is model memory? By any chance can it use external SD cards?
- victzh
- Topic Author
- victzh
- victzh
Device locks out its menus after short inactivity so that you accidentally would not change something important.
The screen is always lit - it should be very low energy consuming one to afford this, but it's very convenient.
It seems to be using unencoded DFUs, they just took examples from DfuSe Demo - which is good!
Couple drawbacks:
1. Low I2C memory - 128kbit is nothing for Deviation filesystem.
2. Antenna is soldered to the board, you need to desolder it to remove the board completely.
3. Many switches, pots, buttons are soldered directly to the board - one good fall - you crack the board. It is a less of drawback, but allowed them to save a lot on assembly cost.
Main problems Deviating it:
1. Flash memory - should be upgraded. Fortunately, the chip is large enough for many people to do this, it's not Devo 7E power limit upgrade.
2. Screen - they used something unnamed, it should be decoded. Visually it very similar to this one: www.aliexpress.com/store/product/2-8-inc...443_32482363327.html , but not necessarily the same.
3. Controls - instead of Devo's 6 buttons this one has two buttons - Enter and Back, and rotary encoder with a button. Need to develop another control procedure for UI.
4. What to do with original radio module. It's 802.15.4/ZigBee, I doubt it can be re-purposed for something useful for more traditional protocols. So it can be replaced with universal module or something like this.
- dc59
- victzh
- dc59
victzh wrote: It's a long way yet. As far as I understand, it's not an OLED, it's just bright LCD with LED background.
You are right, it's a LCD not an OLED.
China RC forum gave me wrong information , sorry.
If it's an LCD, it could difficult to use under sunlight, am I right? just like DEVO 8S.
- victzh
- dc59
victzh wrote: I'll check as soon as we have a sunny day - not this week probably.
Thanks a lot.
- victzh
- Topic Author
- victzh
- adri62
my question is: do you know where the signal to the board is (ppm)
thank you
- anasm2010
i hope more people will be interested and will help on the deviation of the at9.
In my side im working in a mod to control the H8mini quadcopter using a NRF24L01 over the trainer port. I will share when I end
- Home
- Development
- Development
- Radiolink AT9 as a platform for Deviation?
