Is Development Dead for Deviationtx ?
- arthermorgan
- Topic Author
Or should i just invest on RadioMaster Zorro 4in1 transmitter.
For Frsky both versions of ACCST (D16) are supported. ACCESS is not supported. Not sure what's new for Futaba but haven't been any recent changes in that protocol in Deviation.
Update history is here. There've been a few recent updates.
- arthermorgan
- Topic Author
FrSky SPI
ELRS
TBS CRSF
Does the nightly build support these?
I am also interested in XK K110s which uses Futaba S-FHSS.
I know this protcol is listed as supported, just not sure if it will work with K110s. The supported model list has not been updated so can't be sure if these are supported.
Both ELRS and TBS are external transmitter modules that are controlled using the CRSF protocol in Deviation. The link to the transmitter module is a serial data connection. On the Devo 10 that requires connecting the trainer port to the external TX. Look at this post and replies for an example of connecting an external TX module.
I don't know about the K110s. You might check if it's supported by the MultiProtocol Module. If so it should work in Deviation also.
- proteus
- djtrance
DIY-Multiprotocol-TX-Module project.
I really didn't protocols code before for deviation. I helped to develop de devof7 screen and other stuff.
for start working on it , I will try to add F949G subprotols. because I had a receiver for test it.
I hope someone else wanted to help me .
- Zaphod
hexfet wrote: Builds of the latest software are here . The repo automated build is not currently working.
Just checking in for the first time in a while to see if I should do an update to the latest nightly.
The link above to the latest nightly updates take me to a blank page.
Could someone please link me to the latest nightly updates since the automated system isn't working?
Thanks so much.
Zap
- -=Hubi-Dirk=-
- Zaphod
Best to go to the Downloads link in the left column, then Test Builds and look for "[hexfet]nightly_build"
- Home
- Development
- Development
- Is Development Dead for Deviationtx ?
