Is Development Dead for Deviationtx ?
- arthermorgan
11 May 2022 17:01 #77975
by arthermorgan
Is Development Dead for Deviationtx ? was created by arthermorgan
I have been using deviationtx since 2015 on a Devo 7e. Recently got hold of a free Devo 10. Is it worth spending money on a 4 in 1 module ? Is the latest FrSky and Futaba protocols supported on the nightly builds ? I can see the nightly builds have stopped sine June 2021. Is it a dead end for development and protocol update? I see old transmitter turnigy 9x is supported by opentx. What are the chances of Devo transmitter getting opentx or edgetx support.
Or should i just invest on RadioMaster Zorro 4in1 transmitter.
11 May 2022 21:42 #77977
Replied by hexfet on topic Is Development Dead for Deviationtx ?
Builds of the latest software
are here
. The repo automated build is not currently working.
For Frsky both versions of ACCST (D16) are supported. ACCESS is not supported. Not sure what's new for Futaba but haven't been any recent changes in that protocol in Deviation.
Update history is here. There've been a few recent updates.
- arthermorgan
12 May 2022 11:57 #77978
by arthermorgan
Replied by arthermorgan on topic Is Development Dead for Deviationtx ?
Thanks for those links. Managed to install the latest nightly build on the Devo 10. The update history link shows that ELRS and CRSF code has been added. I am interested in some BNF Drones on Banggood that are advertised to support these porotocols:
FrSky SPI
ELRS
TBS CRSF
Does the nightly build support these?
I am also interested in XK K110s which uses Futaba S-FHSS.
I know this protcol is listed as supported, just not sure if it will work with K110s. The supported model list has not been updated so can't be sure if these are supported.
FrSky SPI
ELRS
TBS CRSF
12 May 2022 16:34 #77979
SPI is the interconnect between receiver and flight controller. Somewhere it should say if it's Frsky D8 or D16, both of which are supported by Deviation. As long as it's not Frsky ACCESS protocol it should work.
Both ELRS and TBS are external transmitter modules that are controlled using the CRSF protocol in Deviation. The link to the transmitter module is a serial data connection. On the Devo 10 that requires connecting the trainer port to the external TX. Look at this post and replies for an example of connecting an external TX module.
I don't know about the K110s. You might check if it's supported by the MultiProtocol Module. If so it should work in Deviation also.
- proteus
22 May 2022 09:18 #77996
by proteus
Replied by proteus on topic Is Development Dead for Deviationtx ?
yes XK K110 work fine with 4 i 1 module and S-FHSS protocol
- djtrance
14 Jun 2022 05:45 #78014
by djtrance
Replied by djtrance on topic Is Development Dead for Deviationtx ?
hi, Im back from a long time without develop for deviations. I have not to much time to work on it. but I will try to fix and add some fixed to some protocols for now. I will extract the protocol information of the
DIY-Multiprotocol-TX-Module project.
I really didn't protocols code before for deviation. I helped to develop de devof7 screen and other stuff.
for start working on it , I will try to add F949G subprotols. because I had a receiver for test it.
I hope someone else wanted to help me .
- Zaphod
20 Nov 2022 06:56 #78113
by Zaphod
Just checking in for the first time in a while to see if I should do an update to the latest nightly.
The link above to the latest nightly updates take me to a blank page.
Could someone please link me to the latest nightly updates since the automated system isn't working?
Thanks so much.
Zap
Replied by Zaphod on topic Is Development Dead for Deviationtx ?
hexfet wrote: Builds of the latest software are here . The repo automated build is not currently working.
Thanks so much.
Zap
- -=Hubi-Dirk=-
22 Nov 2022 06:43 #78114
by -=Hubi-Dirk=-
Replied by -=Hubi-Dirk=- on topic Is Development Dead for Deviationtx ?
- Zaphod
22 Nov 2022 10:47 #78115
by Zaphod
Thanks so much! No idea why but i only got a blank page from the link above.
29 Nov 2022 23:29 - 30 Nov 2022 04:47 #78120
Unfortunately the automated nightly build is broken. I've been making a build but url changes with every update. Current is
https://www.deviationtx.com/downloads-new/category/2877-hexfet-nightly-build
Best to go to the Downloads link in the left column, then Test Builds and look for "[hexfet]nightly_build"
Last edit: 30 Nov 2022 04:47 by hexfet.
Time to create page: 0.079 seconds
- Is Development Dead for Deviationtx ?
