Ultimate Devo F12E (devof12e-XMS) builds
06 Apr 2017 10:32 - 11 Apr 2017 03:51 #61212 by vlad_vy
Replied by vlad_vy on topic Ultimate Devo F12E (devof12e-4MB) builds
* Introducing the vastly improved voice alert and voice menu feature, from TheRealMoeder
* cflie_nrf24l01 protocol support for CPPM CRTP commander type, from theseankelly
* Fix devof12e main page for countdown timer with negative value
* Fix no button inputs after renaming mixer
DevoF12E and DevoF12E-4MB, based on Nightly Builds:
Files deleted, see below...
Last edit: 11 Apr 2017 03:51 by vlad_vy.
10 Apr 2017 04:29 - 11 Apr 2017 03:52 #61324 by vlad_vy
* Add Devo F7 (devof7-4MB) and Devo F4 (devof4-4MB) to 4MB builds
DevoF7-4MB and DevoF4-4MB, based on Nightly Builds:
Last edit: 11 Apr 2017 03:52 by vlad_vy.
11 Apr 2017 03:54 - 08 May 2017 14:48 #61370 by vlad_vy
* Fix LCD dimensions for Devo F7 and Devo F4
DevoF12E-4MB, Devo F7-4MB and Devo F4-4MB, based on Nightly Builds:
Last edit: 08 May 2017 14:48 by vlad_vy.
11 Apr 2017 15:55 #61380 by Wene001
Replied by Wene001 on topic Ultimate Devo F12E (devof12e-4MB) builds
Great work as always vlad :-)
If i buy a F7 and do the 4MB mod, can i use Walkera DfuSe USB Tool to install this deviation build?
Anyone here with a 4in1 in the F7?
11 Apr 2017 17:06 - 11 Apr 2017 17:07 #61381 by vlad_vy
Yes. I use Walkera DfuSe USB Tool v2.3.1 for DevoF12E-4MB.
Last edit: 11 Apr 2017 17:07 by vlad_vy.
11 Apr 2017 17:41 - 11 Apr 2017 18:01 #61382 by vlad_vy
Last edit: 11 Apr 2017 18:01 by vlad_vy.
12 Apr 2017 05:30 #61391 by vlad_vy
From Devo F4 and F7 hardware connections I don't see any free GPIO pins for 4in1 connection.
12 Apr 2017 06:07 #61392 by vlad_vy
It looks like A2 (pin 16) do not connected to anything.
24 Apr 2017 16:50 - 24 Apr 2017 16:51 #61733 by passagemaker
Replied by passagemaker on topic Ultimate Devo F12E (devof12e-4MB) builds
is this (see attachment) the right version of the chip?
File Attachment:
File Name: 1669503.pdf
File Size:313 KB
Sorry for the question, but it was mentioned that there are different builds and I have zero clue about electronics.
(my stupidity does not hurt me............. it just hurts when you mention it)
Regards
Richard
Last edit: 24 Apr 2017 16:51 by passagemaker.
24 Apr 2017 16:56 - 24 Apr 2017 16:58 #61734 by vlad_vy
Yes, at the moment you should use SST25VF032B. Other flash memory chips are not supported.
Last edit: 24 Apr 2017 16:58 by vlad_vy.
24 Apr 2017 18:05 #61736 by passagemaker
THANKS!
08 May 2017 14:50 - 19 May 2017 05:48 #62155 by vlad_vy
* Added extra channel for bayang protocol, from silver13
* AFHDS 2A telemetry update, from goebish
* Add H20H format to H8_3D protocol, from goebish
Last edit: 19 May 2017 05:48 by vlad_vy.
19 May 2017 05:49 - 29 May 2017 04:55 #62410 by vlad_vy
* AFHDS-2A LQI output protocol option, from goebish
* CFlie: Adding 'simple' telemetry mode, from theseankelly
Last edit: 29 May 2017 04:55 by vlad_vy.
29 May 2017 04:57 - 01 Jul 2017 14:06 #62668 by vlad_vy
* Protocol H20 Mini & H30 Mini, from goebish
Last edit: 01 Jul 2017 14:06 by vlad_vy.
09 Jun 2017 22:35 #62920 by xuyuan
Replied by xuyuan on topic Ultimate Devo F12E (devof12e-4MB) builds
Thanks @vlad_vy works great for my F7.
BTW, I installed 4 in 1 module, works with 3 RF at the moment, not sure about free pins. You mentioned that A2 is free, but www.deviationtx.com/wiki/hardware/devof7 stats "output to 0 to shut off Tx", how can I check it? or anybody tried?
10 Jun 2017 08:12 #62923 by vlad_vy
I think A2 tested for Devo F4, but probably it will work for Devo F7 also:
www.deviationtx.com/forum/7-development/...o-f4?start=460#51968
28 Jun 2017 18:37 - 28 Jun 2017 18:38 #63192 by SirDomsen
Replied by SirDomsen on topic Ultimate Devo F12E (devof12e-4MB) builds
Excuse that question, but is there a reason why the F_ultimate branches are not going to be merged into the nightlies?
btw: F4 might have sufficient free pins on the MCU as the missing switches compared to the F7 are still there in software...
Last edit: 28 Jun 2017 18:38 by SirDomsen. Reason: typo
29 Jun 2017 03:43 #63201 by vlad_vy
Once again, my answer: I don't know. The pull request was not accepted. Probably 4MB mod has a little followers.
29 Jun 2017 07:25 #63203 by SirDomsen
I see. Just was curious, was assuming AT9 branch might be not common also... too bad.
29 Jun 2017 11:40 #63207 by Wene001
+1 for merging this to the nightlies
Time to create page: 0.134 seconds
