Ultimate Devo F12E (devof12e-XMS) builds
24 Aug 2017 19:00 - 24 Aug 2017 19:02 #63969 by SirDomsen
Replied by SirDomsen on topic Ultimate Devo F12E (devof12e-4MB) builds
finally tested the F4 XMS version. Seems to work pretty well! As M8A4X said, flash memory seems to be increased, I can confirm that. Thanks so much for making the F4 worth to have :)
Best regards
Domsen
Last edit: 24 Aug 2017 19:02 by SirDomsen.
25 Aug 2017 03:54 #63973 by vlad_vy
Replied by vlad_vy on topic Ultimate Devo F12E (devof12e-4MB) builds
Thanks, it looks like Devo F4 work fine as well.
25 Aug 2017 06:13 - 25 Aug 2017 06:45 #63975 by vlad_vy
Since from now we can use flash memory chips with different capacity, it's the time to change name to xxx-XMS. I updated last build with new name. Nothing changed but name only, Also, added emulators for devof12e-XMS and devof7-XMS.
First post also updated with:
ATTENTION! From 25 Aug 2017 we can use different flash memory chips, from series Microchip SST25VFxxxB and SST25VFxxxA, ISSI IS25CQxxx, Winbond W25QxxBV. Reasonable capacity can be started from 8Mbit.
Last edit: 25 Aug 2017 06:45 by vlad_vy.
31 Aug 2017 09:21 - 31 Aug 2017 09:28 #64064 by vlad_vy
Replied by vlad_vy on topic Ultimate Devo F12E (devof12e-XMS) builds
The first nightly build 2017-08-31 for devof12e-XMS. Nothing new, it's the same as 2017-08-25 (message #63944 ).
www.deviationtx.com/downloads-new/category/774-2017-08-31
Last edit: 31 Aug 2017 09:28 by vlad_vy.
01 Sep 2017 09:52 - 07 Sep 2017 08:27 #64092 by vlad_vy
* Add 3pos trim switch functionality, from DavidBoone
Adds the ability to use the momentary trim switches as 3 pos switches. ie, normal resting position is centred (0), while pressing the trim one way or the other results in a momentary deflection in one direction (-100) or the other (+100).
DevoF12E-XMS, Devo F7-XMS and Devo F4-XMS, based on Nightly Builds:
* DevoF12E-XMS can be found at last nightly build.
www.deviationtx.com/downloads-new/category/776-2017-09-01
File deleted, see below...
Last edit: 07 Sep 2017 08:27 by vlad_vy.
07 Sep 2017 08:29 - 11 Sep 2017 10:37 #64268 by vlad_vy
* Add threshold before triggering alarm beep/voice, from TheRealMoeder
* All XMS builds can be found at last nightly build.
Last edit: 11 Sep 2017 10:37 by vlad_vy.
13 Sep 2017 07:53 #64377 by vlad_vy
Judging by the downloads of the Nightly Builds, we have a total of 18 XMS members. Not bad.
13 Sep 2017 17:52 - 13 Sep 2017 17:58 #64380 by SirDomsen
Replied by SirDomsen on topic Ultimate Devo F12E (devof12e-XMS) builds
Totally missed that F4 and F7 XMS made it into the nightlies, too. Great to hear! One download more :D
Last edit: 13 Sep 2017 17:58 by SirDomsen.
13 Sep 2017 19:01 - 13 Sep 2017 19:02 #64381 by KampfGurke
Replied by KampfGurke on topic Ultimate Devo F12E (devof12e-XMS) builds
vlad_vy wrote: Judging by the downloads of the Nightly Builds, we have a total of 18 XMS members. Not bad.
20 B)
Last edit: 13 Sep 2017 19:02 by KampfGurke.
15 Sep 2017 00:52 #64417 by Wene001
Replied by Wene001 on topic Ultimate Devo F12E (devof12e-XMS) builds
21
19 Sep 2017 09:55 #64507 by vlad_vy
35??? The number of XMS members is growing too fast :ohmy:
Probably we need a category (subfolder) at Nightly Builds downloads, as in the case of emulators, "Modded transmitters" (devo7e-256, devof12e-XMS, devof7-XMS and devof4-XMS).
27 Sep 2017 16:07 #64693 by RubenRC
Replied by RubenRC on topic Ultimate Devo F12E (devof12e-XMS) builds
Hey Vlan_vy thanks for the new build you can add me to your XMS member as well. I finally fixed my F12E and got it loaded last night and it works great! So you can make it 36 now :-)
DEVO F12E | Devo F7
28 Sep 2017 19:04 #64724 by vlad_vy
I can add to Devo F series empty quick page for use with external OSD. You can select that page ("External OSD") at "Main page config" menu (for Menu 1, Menu 2, Menu 3 or Menu 4), and switch from main page to OSD page by long press UP or DOWN button (and return back to main page).
What do you think about it?
28 Sep 2017 19:06 #64725 by FDR
Aha!, That's why you need to correct the quick page bug... ;)
28 Sep 2017 19:11 - 28 Sep 2017 19:19 #64726 by vlad_vy
You caught me. I already use the firmware with fixed quick pages bug and the OSD page.:P
Last edit: 28 Sep 2017 19:19 by vlad_vy.
29 Sep 2017 03:59 - 20 Oct 2017 04:08 #64733 by vlad_vy
* Fix Quick Pages, from vladislavy
* Add "External OSD" empty page to Quick Pages, from vladislavy
Test build for DevoF12E-XMS, Devo F7-XMS and Devo F4-XMS, based on Nightly Builds:
Files deleted, see Nightly Builds...
Last edit: 20 Oct 2017 04:08 by vlad_vy.
10 Oct 2017 21:10 - 10 Oct 2017 21:16 #64953 by Wene001
Hi Vlad
I`m a long time Devo12s (and 6s) user, and now i have a F7 XMS.
Thanks for the great work with your XMS builds.
Technical it works very fine.
But the visbility of the menues is not perfect for me.
The standard selector is hard to see, because its part of the text
What do you think about changes like on the pictures. ( Do we need the numbers in the menues?)
Would be fine to have a standard selector(cursor) that isn`t moving the text to the right
And another "bug"? is that the Trim Display (on F7 ) doesnt behave the same in both directions.
Tested with the F12E Simulator this is fine.
Last edit: 10 Oct 2017 21:16 by Wene001.
10 Oct 2017 22:55 #64954 by kmewes
Replied by kmewes on topic Ultimate Devo F12E (devof12e-XMS) builds
Hi Wene001, Vlad,
About the cursor modification in the menu, how about inverting the text you're at, i.e. highlighting the selection instead of displaying a cursor? I think the display supports this and it should be nicely readable since it is not an overlay. I don't know how it would look on the F4/F7/F12 with an image in the background, which can be turned off though (I use one of the AUX knobs to turn it on/off).
Love my 8S though, don't know why anyone that doesn't do FPV would use a non-GUI/non-touch display (-;
Regards.
11 Oct 2017 03:48 - 11 Oct 2017 04:31 #64956 by vlad_vy
About cursor with two arrows: With devoF4 and devoF7 we have very limited line length (24), so we haven't enought space for fields at many places, I waste long time to fit all things as possible. But still there were places with cropped text.
About devoF7 trims: devoF4 video chip has very limited char set, so this is done as possible.
About inverted selection, by sorry the TW8816 video chip doesn't support every symbol properties, only at window level, so it's impossible. At the best, we can select the whole line by placing it in a separate window. That suitable for menus only.
Probably devof12e GUI can be better, but it will require the development of a separate GUI for devof12e.
Last edit: 11 Oct 2017 04:31 by vlad_vy.
11 Oct 2017 14:27 #64958 by kmewes
I understand that the limitations are in the chips OSD display functions and you have tried many possibilities I'm sure. The features of the TW8816 OSD that came to my attention and could be used in menus were character color and character background color as well as character blinking. But is the additional time spent in reprogramming worth the effort considering the limitation of the text display in the OSD in general, that's the question. I'm fine with the way it looks right now btw.
Regards
Time to create page: 0.110 seconds
