Ultimate Devo F12E (devof12e-XMS) builds
15 Apr 2018 08:24 #68661 by vlad_vy
Replied by vlad_vy on topic Ultimate Devo F12E (devof12e-XMS) builds
"non-XMS" what???
devo12 will work without problems, but "media" folder will be inaccessible (at library file).
devof4, devof7 and devof12e have unstable compact filesystem (devo.fs), and at any time you can get damaged filesystem.
15 Apr 2018 08:32 #68662 by KnzHz
Replied by KnzHz on topic Ultimate Devo F12E (devof12e-XMS) builds
Hehe, I simply meant the build that didn't have XMS in the name ;)
Okay, so limitations is stability and and the ability to upload to media, so that's sounds etc?
I'll probably do the mod, but I just want to check out how it works on my demo f12e first ;)
So far it's pretty cool ;)
Thank you for the quick answer and all your hard work!
10 May 2018 20:17 #69173 by Bcacres
Replied by Bcacres on topic Ultimate Devo F12E (devof12e-XMS) builds
I have found this topic dealing with modding the F12E very interesting.
Before I dive into making this mod, are there any regrets from anyone?
11 May 2018 05:02 #69176 by vlad_vy
* More reliable and beep only once "beep" mux
* More reliable and sound only once "voice" mux
"devo12-XMS" based on nightly builds:
(11-05-2018)
File Attachment:
File Name: deviation-...5-11.zip
File Size:879 KB
28 May 2018 10:17 - 28 May 2018 10:17 #69443 by vlad_vy
* Fix display of text in startup warnings
* Optimize GUI redraw
Avoid full page redraw for any scrollable object change. It looks much more naturally if updated the scrollable area only, but not the full page.
Avoid full page redraw with every item position change at "Main layout edit" page.
Avoid full page redraw after close any dialog window.
Optimize redraw objects after close dialog window, redraw underlying objects only.
(28-05-2018)
File Attachment:
File Name: deviation-...5-28.zip
File Size:880 KB
Last edit: 28 May 2018 10:17 by vlad_vy.
29 May 2018 13:47 #69459 by Bcacres
I need a little help please!
I have replaced the chip in question with a SST25VF032B in my F12E.
When I connected to PC, it did not show up as a USB drive, not recognized by the java uploaders, only by USB upgrade tool 2.3x.
I tried uploading lastest DFU firmware but when I test out radio it’s only a blank screen. I tried several attempts with different loads and the only one that will work is the original ver 1.5A or other older versions.
Am I doing something wrong here?
Please help
29 May 2018 14:03 - 29 May 2018 14:10 #69460 by vlad_vy
You need flash devof12e-XMS firmware from Nightly builds. Next, press ENT + Power On, format transmitter USB drive and write filesystem from firmware archive.
www.deviationtx.com/downloads-new/catego...s-v5-0-0-9b44f22-zip
Last edit: 29 May 2018 14:10 by vlad_vy.
30 May 2018 11:45 #69476 by Bcacres
Thank you for the help I did as you instructed and now it shows up as USB drive . The computer Will tell me I need to format the drive in order to use it but when I attempt to do that it keeps saying please insert the device or that it’s not accessible. I’ll even right click on the drive that continues to show up but can’t do anything with it .
I would greatly appreciate some help with this matter .
Thanks in advance !
30 May 2018 12:38 #69477 by vlad_vy
It looks like you flash memory chip not working. Check flash memory chip soldering and connections.
With Devo F12E it will be (pin connections from SST25VF032B to STM32F103VCT6):
1. CE = GND (VSS_4, pin 27)
2. SO = SPI1_MISO (PA6, pin 31)
3. WP = 3.3V (VDD_4, pin 28)
4. VSS = GND (VSS_4, pin 27)
5. SI = SPI1_MOSI (PA7, pin 32)
6. SCK = SPI1_SCK (PA5, pin 30)
7. HOLD = 3.3V (VDD_4, pin 28)
8. VDD = 3.3V (VDD_4, pin 28)
01 Jun 2018 10:07 #69498 by RubenRC
Replied by RubenRC on topic Ultimate Devo F12E (devof12e-XMS) builds
You flash memory is not completely soldiered down on the board. 1 of the pads isn't making contact most likely a write pin. That's exactly the issue I had. I got it down on the board good and never saw the problem again B)
DEVO F12E | Devo F7
01 Jun 2018 14:01 #69504 by Bcacres
Last night I checked and rechecked and recheck continuity with an ohm meter between each point from the legs of the new flash chip to the legs of the main chip as discribed two posts above. Every path checked out solid connection and not shorted to any other pin points other than 3-7-8 and 1-4.
I tried every possible combination of flashing chip and every time if it showed up in explorer, it would not allow me to format it. Same as I have read in previous posts.
01 Jun 2018 14:09 - 01 Jun 2018 16:58 #69505 by Bcacres
I woke up @ 2:30 this morning thinking about maybe the pin paths to the main chip might were not correct as discribed above. I pulled out another Devo F12E I have, opened it up and began to compare paths.
What I found is that pin 1 on the flash chip goes through a Resistor chip (103) before it goes to pin 27 of the main chip. So pin 1 and pin 4 of the chip are not common.
I rerouted pin 1 to the correct side of the 103 resistor chip but I may have damaged the chip because I still have the same flashing firmware problem.
I will replace it tonight and try again.
Last edit: 01 Jun 2018 16:58 by Bcacres. Reason: Correction
01 Jun 2018 15:41 #69507 by Bcacres
A detailed step-by-step process for flashing and so forth from beginning to end with what program used and what tab for each step and drivers used would be very helpful for this newbie. Key word “DETAILED”
For the F12E
02 Jun 2018 06:18 - 02 Jun 2018 06:57 #69516 by vlad_vy
For devof12e-XMS see DEVO 7E/10/12E user manual
www.deviationtx.com/user-manual
Last edit: 02 Jun 2018 06:57 by vlad_vy.
06 Jun 2018 00:50 #69565 by Bcacres
I’m up and running now! Thanks for the help!
10 Jun 2018 15:19 #69598 by Bcacres
vlad_vy wrote: It looks like you flash memory chip not working. Check flash memory chip soldering and connections.
On my F12E I found Pin 1 to go through a resistor first before going to Pin 27 of the MCU. And I also found that pin 1 goes to Pin 37 of the MCU.
See pic...
11 Jun 2018 06:24 - 11 Jun 2018 06:28 #69605 by vlad_vy
DevoF12E the flash memory chip connections corrected:
1. CE = SPI1_CE (PB2, pin 37)
With Devo F4 it can be (pin connections from SST25VF032B to STM32F103RBT6):
1. CE = SPI1_CE (PB2, pin 28)
2. SO = SPI1_MISO (PA6, pin 22)
3. WP = 3.3V (VDD_4, pin 19)
4. VSS = GND (VSS_4, pin 18)
5. SI = SPI1_MOSI (PA7, pin 23)
6. SCK = SPI1_SCK (PA5, pin 21)
7. HOLD = 3.3V (VDD_4, pin 19)
8. VDD = 3.3V (VDD_4, pin 19)
Last edit: 11 Jun 2018 06:28 by vlad_vy.
16 Jun 2018 19:02 #69657 by Theoretiker
Replied by Theoretiker on topic Ultimate Devo F12E (devof12e-XMS) builds
Hi Vladimir,
you made a great job. Thanks for your work and your support.
But no I have a problem to modify my Devo F12e with the XMS Mod.
i changed the Chip and updated the firmware with the XMS-f31c081. i use the java tool V0.9
Than i got problem to format the chip.
i also try the original Wlakera tool and push the button "leave DFU Mode"
The computer didn't found the device. i thought i made a misstake, so a changed the chip back.
take the old firmware and put everything back.
Now there is a message "Battery too low. can't safe!" i put my old devo.fs file (64kb) but the devo can't read or write something.
Do you know someting about it?
i measured the volatage on the battery 10,4V on the chip 3,3V.
If the message comes, the value at the battery is the same.
The Battery value in the devo.fs file was 54.0 and i tried also 102.1 (value from a friend who has also a modified DevoF12e)
A friend made the same modification and everything works well.
i have to say, that i have modified my both Devo 7e and replace the chip and made the modification with the 3 way switch...
So i know some informations how to make the modifikations.
But now I am finished with my knowledge.
regards Oliver
Made some tiny radio controlled vehicles in scale 1:87
2x Devo 7e with chip modification, 4x3 way swithes, 3in1 transmitter chip
1x Devo 10
1x Devo F12e
Webseite: www.der-theoretiker.de
Youtube: www.youtube.com/user/Mikromodelle
22 Feb 2019 20:48 #72973 by Toolbox1211
Replied by Toolbox1211 on topic Ultimate Devo F12E (devof12e-XMS) builds
Thank you every one here for all the information. due to your help I now have a deviated f12e xms.
I was scared to do this being my first time soldering anything other than a wire but was successful on my first go due to the excellent information here
26 Feb 2019 18:46 #73031 by wind10071
Replied by wind10071 on topic Ultimate Devo F12E (devof12e-XMS) builds
Who can provide a F12E screen motherboard picture, can see the screen interface in detail, circuit board model and screen component circuit diagram, thank you
Time to create page: 0.079 seconds
