iRangeX iRX-IR8M builds no more?!
09 Aug 2018 10:45 #70177 by mchaves
Replied by mchaves on topic iRangeX iRX-IR8M builds no more?!
No more iRX-IR8M builds?
tks
09 Aug 2018 15:46 #70184 by vlad_vy
Replied by vlad_vy on topic iRangeX iRX-IR8M builds no more?!
See Nightly builds.
10 Aug 2018 09:50 #70197 by mchaves
Where I get it? tks
10 Aug 2018 13:21 #70203 by vlad_vy
11 Aug 2018 01:19 #70211 by mchaves
tks
30 Sep 2018 13:45 #71103 by GabrielRB
Replied by GabrielRB on topic iRangeX iRX-IR8M builds
Yesterday I updated my IR8M from original firmware to last build.
Using my Tiny Whoop I started to experience some lose control issues. So I make a range test:
Radio - 100uW
Receiver - Tiny Whoop FrSky D8 protocol
Latest nightly build - about 6m
Original build - much more than 10m (impossible to check inside my apartment)
Its possible that last build have range issues on D8 protocol?
01 Oct 2018 06:59 #71115 by vlad_vy
I suspect iRangeX has some specific code change for 4IN1_FLASH, with "4in1" RF module output power lines (PE1 and PE2) management. We have not any contacts with iRangeX, so I don't know how to fix it.
01 Oct 2018 09:34 - 01 Oct 2018 10:18 #71120 by suzygs1000
Replied by suzygs1000 on topic iRangeX iRX-IR8M builds
I just upgraded my Irangex with the latest firmware, and the screen is black, and the power is connected as soon as I connect the battery. I can still get into dfu mode, by holding the ext button while plugging the batteryu in. How can I fix this?
Ok, I have now upgraded with Devo 8 - v5.0.0., which someone on the forum provided as the original fw for v1 . Power switch now works ok, but still have blank screen.
thanks Dave.
Last edit: 01 Oct 2018 10:18 by suzygs1000.
01 Oct 2018 10:32 #71122 by mchaves
Hi suzygs1000, I solved it by returning some versions, it follows that I keep as an emergency recovery
01 Oct 2018 23:04 #71131 by GabrielRB
vlad_vy wrote: I suspect iRangeX has some specific code change for 4IN1_FLASH, with "4in1" RF module output power lines (PE1 and PE2) management. We have not any contacts with iRangeX, so I don't know how to fix it.
I'm starting to wonder if some of range complains are no related to firmware update...
In any case my recommendation is to keep original .dfu saved somewhere as a backup just in case.
Just to highlight I was able to reach 2km with FrSky receivers using this radio+external antenna. So unless the module have the bad welding/shorts pins showed by some users this radio should work fine (even though everybody say that is totally garbage).
04 Oct 2018 03:47 #71170 by suzygs1000
Thanks, mate ... I had backed up my original files, so I have reflashed with the original firmware, and back to original now. My problem is that I can't use it with Walkera RX601 receivers, otherwise all good.
Davd.
08 Dec 2018 01:02 #72009 by QuadRacer39
Replied by QuadRacer39 on topic iRangeX iRX-IR8M builds
Hi there, I am new here but have been into racing RC cars for over 20 years now. 2 years ago I built my first FPV quad, a Martian 2, 5" frame. Now I have more quads than I can count.
Anyway, I gave this TX a try cause it was so cheap. When I got it, it would only give 2 missing module errors. After many tries re-flashing, and attempting to return it for a refund, I decided to try to repair it. So I took a 4 in 1 I had with the ARM chip from BANGGOOD, that was built for a Flysky tx, and removed the 4in1 module from both the iRange and the add on assembly, then installed the BGmodule into the iRange and....Voila! Now it works.
I'd bet that there are a LOT more faulty modules out there than mine. Could be the range issue I keep reading about.
Now I have figured out how to bind it and store my models in memory, but still cannot figure out how to program all my Aux switches. I want SW-B to be ch 5, A is ch 6, D-7, C-8, and the right top switch to be ch 9. I use this setup for all my quads.
CAN SOMEONE PLEASE FILL ME IN OR POINT ME TO THE PAGE I NEED TO READ TO FIGURE IT OUT PLEASE??
I am lucky to get any flight time these days. I spent my last 2 chances fiddling with this transmitter, trying to get it to work. I'd really like to fly using it now that I have it working.
Thanks,
QuadRacer39
08 Dec 2018 02:31 #72011 by sfjuocekr
Replied by sfjuocekr on topic iRangeX iRX-IR8M builds
Make a complex mixer, use two or three pages and set each page to replace with a fixed value.
10 Dec 2018 12:20 #72039 by FDR
Replied by FDR on topic iRangeX iRX-IR8M builds
Actually if you want to assign a two state switch to a channel, it is as simple as select one of the switch states as the source of a simple mixer. This way it will give you -100% or +100% depending on the switch state...
For the 3 way switches I prefer to use the DR&Expo template with "fixed" function, and use three values for each state, usually -100%, 0%, and +100%.
11 Dec 2018 18:03 #72051 by Medhy11700
Replied by Medhy11700 on topic iRangeX iRX-IR8M builds
Hello, I am new user of the irangex i8x, my problem is that I still can not assign AUX channels on switch 3 positions -100 / 0 / + 100! radio version t8sg-v5.x.x-2017-09-19. which compatible firmware? thank you for your help!
ps: I use a translator to communicate. cordially
02 Feb 2019 21:08 #72675 by backman8571
Replied by backman8571 on topic iRangeX iRX-IR8M builds no more?!
Do you have a build for Devo 12S
02 Feb 2019 21:28 #72678 by Medhy11700
Replied by Medhy11700 on topic iRangeX iRX-IR8M builds no more?!
bonjour , pas de devo 12s ! la 7e.
quelle mise a jour faudrait ?
02 Feb 2019 21:37 #72679 by backman8571
I would use a multi mode RF module 4 in 1
02 Feb 2019 21:37 #72680 by backman8571
And i would need help with where do you solder the leads for 12s and also for F12E
28 Feb 2019 10:55 #73064 by dheku
Replied by dheku on topic iRangeX iRX-IR8M builds
Hi.I use i8x-ir8m.
Today, I updated firmware to deviation-ir8m-v5.0.0-2455ad1.
Problem has occurred so it indicated alert as missing modules A7105.
I confirmed hadrware.ini but it was not incorrect that enable A7105.
I want to fix this problem.
The problem was solved after changing firmware to deviation-ir8m-v5.0.0-b08efa8.
Is this bug?
Time to create page: 0.081 seconds
