iRangeX iRX-IR8M builds no more?!
06 Mar 2019 20:27 #73241 by BIllyU
Replied by BIllyU on topic iRangeX iRX-IR8M builds
Hi. I formatted USB drive and now the Tx is not seen anymore by PC as a disk. It is seen as DFU device, but not as a disk. Can somebody help?
Thanks.
06 Mar 2019 22:35 #73244 by clips
Replied by clips on topic iRangeX iRX-IR8M builds
dheku wrote: Hi.I use i8x-ir8m.
Today, I updated firmware to deviation-ir8m-v5.0.0-2455ad1.
Problem has occurred so it indicated alert as missing modules A7105.
I confirmed hadrware.ini but it was not incorrect that enable A7105.
I want to fix this problem.
The problem was solved after changing firmware to deviation-ir8m-v5.0.0-b08efa8.
Is this bug?
would u sent me deviation-ir8m-v5.0.0-b08efa8 or share link to download this file, i have same problem like missing modules A7105
07 Mar 2019 06:16 #73248 by Moeder
Replied by Moeder on topic iRangeX iRX-IR8M builds
Update to most recent nightly, that should possibly solve the issue. There was a bug which has been resolved which could affect module communication.
08 Mar 2019 15:26 #73268 by dheku
Replied by dheku on topic iRangeX iRX-IR8M builds
Uploaded that file.
14 Mar 2019 18:49 #73357 by jesus1319
Replied by jesus1319 on topic iRangeX iRX-IR8M builds
Buenas tardes:
Por favor, alguien me puede decir donde encontrar el archivo para la actualizaciĆ³n? gracias!!
14 Mar 2019 20:50 #73358 by Medhy11700
Replied by Medhy11700 on topic iRangeX iRX-IR8M builds
Bonjour. C'est quoi le module 4en1 ? Merci
14 Mar 2019 22:20 #73361 by mchaves
Replied by mchaves on topic iRangeX iRX-IR8M builds
Boa noite, Downloads/Nightly Builds ( www.deviationtx.com/downloads-new/category/13-nightly-builds ) ok?
15 Mar 2019 10:44 #73371 by jesus1319
Ok, muchas gracias!!!
16 Mar 2019 11:21 #73387 by clips
dheku wrote: Uploaded that file.
thank u, it Work
17 Mar 2019 17:32 #73396 by Bigsexy06
Replied by Bigsexy06 on topic iRangeX iRX-IR8M builds
Deleted see bellow? Where? I am at a usb screen that will not go away and have tried 5 times to go through the process with no luck my tx still in usb mode. How do i fix? Does anyone know the links and how to fix this usb issue? No one on fb has a clue i am hoping someone here does
17 Mar 2019 17:44 #73397 by zinets
Replied by zinets on topic iRangeX iRX-IR8M builds
hi guys
i've got message "missing modules cyrf6936" today after charging lipo (i use 2s lipo connected instead of battery pack)
then i updated firmware to latest (succ), formatted flash and copied files from zip to internal flash (succ) but error still remain
my irangex has version 1.1
could high voltage (8.4V - too high?) damage transmitter module? cant see any ways to fix this issue (i googled internet very throughly) :(((
18 Mar 2019 08:45 #73408 by mchaves
Hi, my IR8 is V1.1 and I use 2 x 16340 Li-Ion (previously used two 2800mAh cell phone batteries) this for a year and no problems.
18 Mar 2019 15:24 #73413 by Bigsexy06
Deezyy's drone reviews and deals just posted the fix that fixed mine. Check it out on YouTube
31 Mar 2019 15:44 #73641 by Pongetti
Replied by Pongetti on topic iRangeX iRX-IR8M builds
I have updated today's firmware. My I8X-IR8M gives the following error: Missing Modules: A7105.
Only the deviation-ir8m-v5.0.0-b08efa8 firmware does not give this error.
The hardware.ini file is the same as the original.
How can I solve it?
31 Mar 2019 17:17 #73644 by Bigsexy06
Hi everyone go to Deezyy's drone reviews and deals on YouTube. He give me a link that solved the USB lock issue. He posted a video of the cure. It fixes other issue's as well
03 Apr 2019 23:11 #73677 by fonristofen
Replied by fonristofen on topic iRangeX iRX-IR8M builds
Hi everyone, I'm new so forgive me if I screw up. I have the Irange i8X-IR8M and I have done the whole process to install deviation-ir8m-v5.0.0-8cfcb5d, I can not because it tells me that there is a lack of space in the station memory the update has 2Mb and the station is missing 260 kb for I can install it, someone can help me, thanks.
04 Apr 2019 18:26 #73688 by Pongetti
watch this video
Do not copy the file .dfu in the memory of i8X-IR8M
04 Apr 2019 22:13 #73693 by BIllyU
Don't copy the zip file.
17 Apr 2019 20:15 #73965 by teo-costin
Replied by teo-costin on topic iRangeX iRX-IR8M builds
Hello
Where can I find the latest firmware for this radio?
How do I know if it is V1 or V2?
17 Apr 2019 22:36 #73969 by mchaves
Hi, look in downloads\Nightly Builds (link above).
Time to create page: 0.072 seconds
