Devo 8
- Topic Author
28 Jun 2013 18:39 - 28 Jun 2013 18:56 #11527
Devo 8 was created by vlad_vy
Devo 8 (Nightly Builds). First attempt to create custom layout templates.
Last edit: 28 Jun 2013 18:56 by vlad_vy.
- Topic Author
27 Jul 2013 11:46 - 21 Oct 2013 13:29 #12549
Replied by vlad_vy on topic Devo 8
Last edit: 21 Oct 2013 13:29 by vlad_vy.
- stevecox
- Keep swinging
- Topic Author
21 Oct 2013 14:30 #14836
Layout 'Devo8-48.ini' had wrong trims placement, now it's corrected.
- WheresWaldo
21 Oct 2013 16:55 #14846
by WheresWaldo
- Topic Author
21 Oct 2013 17:05 #14847
These layouts are for Devo8, for Devo10/7 they do nothing.
- WheresWaldo
21 Oct 2013 17:45 - 21 Oct 2013 17:56 #14849
by WheresWaldo
You have to use the 3.1 nightly from rbe, the layout file will go into the /layout directory. You can now use the exact same file for Devo 8 (it will show 8 channels and model icon) or Devo 7/10 (it will show 6 channels and no model icon).
BTW, there are no R E A icons with up arrows in Devo 7/10 so I used the down arrows and the inverse when toggled. Tell me what you think.
You could also add the [gui-480x272] section to the ini file and it would customize the same gui for the Devo12. It would sure be nice if we could just have one set of ini files to cover the whole range of Devo TXs.
Replied by WheresWaldo on topic Devo 8
I fixed it, look here it does work! vlad you have to think outside the box sometimes.vlad_vy wrote: These layouts are for Devo8, for Devo10/7 they do nothing.
Last edit: 21 Oct 2013 17:56 by WheresWaldo. Reason: More clarifying text.
- Topic Author
02 Jan 2014 08:47 #17715
Time to create page: 0.122 seconds
