Devo 8
28 Jun 2013 18:39 - 28 Jun 2013 18:56 #11527 by vlad_vy
Devo 8 was created by vlad_vy
Devo 8 (Nightly Builds). First attempt to create custom layout templates.
File Attachment:
File Name: Devo8-6.ini
File Size:0 KB
File Attachment:
File Name: Devo8-4.ini
File Size:0 KB
File Attachment:
File Name: Devo8-4i.ini
File Size:0 KB
Last edit: 28 Jun 2013 18:56 by vlad_vy.
27 Jul 2013 11:46 - 21 Oct 2013 13:29 #12549 by vlad_vy
Replied by vlad_vy on topic Devo 8
File Attachment:
File Name: Devo8-48.ini
File Size:1 KB
Last edit: 21 Oct 2013 13:29 by vlad_vy.
27 Jul 2013 19:48 #12557 by stevecox
Replied by stevecox on topic Devo 8
That last one is sweet just my cup of tea thanks!
Adelaide
21 Oct 2013 14:30 #14836 by vlad_vy
Layout 'Devo8-48.ini' had wrong trims placement, now it's corrected.
21 Oct 2013 16:55 #14846 by WheresWaldo
Replied by WheresWaldo on topic Devo 8
vlad_vy , I am going to copy this to the Devo10/7 nightly if you don't mind. I want to make sure that layouts are consistent from model to model, as much as they can be.
21 Oct 2013 17:05 #14847 by vlad_vy
These layouts are for Devo8, for Devo10/7 they do nothing.
21 Oct 2013 17:45 - 21 Oct 2013 17:56 #14849 by WheresWaldo
vlad_vy wrote: These layouts are for Devo8, for Devo10/7 they do nothing.
I fixed it, look here it does work! vlad you have to think outside the box sometimes. :)
You have to use the 3.1 nightly from rbe, the layout file will go into the /layout directory. You can now use the exact same file for Devo 8 (it will show 8 channels and model icon) or Devo 7/10 (it will show 6 channels and no model icon).
BTW, there are no R E A icons with up arrows in Devo 7/10 so I used the down arrows and the inverse when toggled. Tell me what you think.
You could also add the [gui-480x272] section to the ini file and it would customize the same gui for the Devo12. It would sure be nice if we could just have one set of ini files to cover the whole range of Devo TXs.
Last edit: 21 Oct 2013 17:56 by WheresWaldo. Reason: More clarifying text.
02 Jan 2014 08:47 #17715 by vlad_vy
One more Devo8 layout
File Attachment:
File Name: Devo8-49.ini
File Size:1 KB
Time to create page: 0.253 seconds
