High contrast WB skin (thanks to FDR)
10 Nov 2013 13:06 #15493 by EduardS
High contrast WB skin (thanks to FDR) was created by EduardS
Based on FDR's high contrast black on white skin I have made a high contrast white on black skin. I think it's readability in sunlight suffices and a big gain is that it uses less energy than the high contrast black on white skin.
10 Nov 2013 14:54 #15496 by FDR
Replied by FDR on topic High contrast WB skin (thanks to FDR)
EduardS wrote: ...and a big gain is that it uses less energy than the high contrast black on white skin.
Actually no, it uses the same amount of energy, since the backlight is the same...
10 Nov 2013 15:39 - 10 Nov 2013 17:30 #15497 by EduardS
Replied by EduardS on topic High contrast WB skin (thanks to FDR)
LOL, damn I could have sworn my Devo8s worked longer on this skin. :lol:
Last edit: 10 Nov 2013 17:30 by EduardS.
03 Jan 2014 11:36 #17828 by Kdean
Replied by Kdean on topic High contrast WB skin (thanks to FDR)
I like the look of the darker skin. How can i get this for a devo12?
03 Jan 2014 13:42 #17837 by billmester
Replied by billmester on topic High contrast WB skin (thanks to FDR)
Lower power consumption would be true IF the screen would be LED not LCD ;-)
With LCD, it is a bit more even, 'cause apart from the same backlight, more pixels (with the driver transistors) are needed to be activated... but it is sooo little difference :-)
LCD: when active, covers the light coming from the backlight( = black or some colour means power use, white = no power use on a pixel)
LED: pixels emit the light themselves (black pixel = no power)
Happy New Year to all of you! Good job releasing v4!
Already on and under testing ;-)
cheers
bm
  • rbe2012
  • rbe2012's Avatar
03 Jan 2014 18:25 #17877 by rbe2012
Replied by rbe2012 on topic High contrast WB skin (thanks to FDR)
Kdean wrote: I like the look of the darker skin. How can i get this for a devo12?
You have to build your own library dfu file. It contains the "media" folder with all files inside in a FAT file system.
I am working to create a build-system independent method to create this library-dfu but I am not sure if I will succeed at last...
If you have a working build environment (MinGW under Windows) you can execute the attached script (in MinGW-Window) with executing "sh make-lib.sh WORKING-FOLDER" (in the src/-folder of the deviation repository).
The WORKING-FOLDER is the folder where you have put a copy the files in filesystem/devo12/media in a subfolder "media", e.g.
mkdir ~/make-lib
mkdir ~/make-lib/media
cp filesystem/devo12/media/* ~/make-lib/media/
sh make-lib.sh
15 Apr 2014 23:18 #22435 by unclecrash
Replied by unclecrash on topic High contrast WB skin (thanks to FDR)
I know this is old but I really like this skin,it would look sweet on the 12s I have. Im going to have to con my Nephew to see if he can do it for me.
09 May 2014 00:42 #23047 by dat
Replied by dat on topic High contrast WB skin (thanks to FDR)
i hope the skin can work in 12s on sunnyday make 12s color screen eazy read too ! someone can help update it ?
Time to create page: 0.119 seconds
