High contrast WB skin (thanks to FDR)
- EduardS
10 Nov 2013 14:54 #15496
Replied by FDR on topic High contrast WB skin (thanks to FDR)
Actually no, it uses the same amount of energy, since the backlight is the same...EduardS wrote: ...and a big gain is that it uses less energy than the high contrast black on white skin.
- EduardS
10 Nov 2013 15:39 - 10 Nov 2013 17:30 #15497
by EduardS
LOL, damn I could have sworn my Devo8s worked longer on this skin.
Replied by EduardS on topic High contrast WB skin (thanks to FDR)
Last edit: 10 Nov 2013 17:30 by EduardS.
- Kdean
03 Jan 2014 11:36 #17828
by Kdean
Replied by Kdean on topic High contrast WB skin (thanks to FDR)
I like the look of the darker skin. How can i get this for a devo12?
- billmester
03 Jan 2014 13:42 #17837
by billmester
Replied by billmester on topic High contrast WB skin (thanks to FDR)
Lower power consumption would be true IF the screen would be LED not LCD
With LCD, it is a bit more even, 'cause apart from the same backlight, more pixels (with the driver transistors) are needed to be activated... but it is sooo little difference
LCD: when active, covers the light coming from the backlight( = black or some colour means power use, white = no power use on a pixel)
LED: pixels emit the light themselves (black pixel = no power)
Happy New Year to all of you! Good job releasing v4!
Already on and under testing
cheers
bm
cheers
bm
03 Jan 2014 18:25 #17877
I am working to create a build-system independent method to create this library-dfu but I am not sure if I will succeed at last...
If you have a working build environment (MinGW under Windows) you can execute the attached script (in MinGW-Window) with executing "sh make-lib.sh WORKING-FOLDER" (in the src/-folder of the deviation repository).
The WORKING-FOLDER is the folder where you have put a copy the files in filesystem/devo12/media in a subfolder "media", e.g.
Replied by rbe2012 on topic High contrast WB skin (thanks to FDR)
You have to build your own library dfu file. It contains the "media" folder with all files inside in a FAT file system.Kdean wrote: I like the look of the darker skin. How can i get this for a devo12?
mkdir ~/make-lib
mkdir ~/make-lib/media
cp filesystem/devo12/media/* ~/make-lib/media/
sh make-lib.sh- unclecrash
15 Apr 2014 23:18 #22435
by unclecrash
Replied by unclecrash on topic High contrast WB skin (thanks to FDR)
I know this is old but I really like this skin,it would look sweet on the 12s I have. Im going to have to con my Nephew to see if he can do it for me.
- dat
09 May 2014 00:42 #23047
by dat
Replied by dat on topic High contrast WB skin (thanks to FDR)
i hope the skin can work in 12s on sunnyday make 12s color screen eazy read too ! someone can help update it ?
Time to create page: 0.279 seconds
Custom Skins
- High contrast WB skin (thanks to FDR)
