How to change THR display value ?
- geehome
07 Apr 2013 13:39 #8682
by geehome
How to change THR display value ? was created by geehome
Hello, I want to see a display value of the THR has 0/100 and not -100/100 on my home page, How to make it please ?
And thank again for your great work
07 Apr 2013 13:56 - 07 Apr 2013 13:57 #8684
Replied by vlad_vy on topic How to change THR display value ?
You can use any unused channel to setup:
1) Mix: Simple
2) Src: THR
3) Curve: 1-to-1
4) Scale: 50
5) Offset: 50
And select this channel for a box at Main page config.
Will be nice to use for that a virtual channel, but at current time it's impossible to display virtual channel at boxes.
Issue #280
bitbucket.org/PhracturedBlue/deviation/i...-at-main-page-config
1) Mix: Simple
2) Src: THR
3) Curve: 1-to-1
4) Scale: 50
5) Offset: 50
Issue #280
Last edit: 07 Apr 2013 13:57 by vlad_vy.
07 Apr 2013 13:59 #8685
Replied by FDR on topic How to change THR display value ?
Even better to use the Ch3 (or Ch1 depending on the protocol) as the source...
07 Apr 2013 14:09 #8686
Exactly, this way you get output value, not stick position.
- yidc
02 Jan 2014 17:28 #17753
by yidc
Replied by yidc on topic How to change THR display value ?
I'm now using virtual channel to display +ve throttle value (ch3)
But when throttle hold is ON, virtual channel will ignore this and still display ch3 value
any idea on this?
I also checked channel monitor, when throttle hold is ON, ch3 always show -100%, but virtual channel still show +ve value
hummmmmm strange
any idea on this?
hummmmmm strange
02 Jan 2014 17:37 #17755
If you use THR as the source for virtual channel it is throttle stick position. You can try to use CH3.
- yidc
03 Jan 2014 02:04 #17800
by yidc
vlad_vy,
Yes I'm already using CH3 as source of my virtual channel.
Like what I said before, when throttle hold is ON, channel monitor shows CH3 always show -100%, but virtual channel still show +ve value
03 Jan 2014 04:04 #17807
Probably you use channel safety for throttle hold and it applied after mixer. Try to create one more complex mixer page for throttle and use it for throttle hold.
- yidc
03 Jan 2014 06:42 #17818
by yidc
Yes u're correct, I'm using channel safety for THR at this moment
How do I use complex mixer as throttle hold? Choose the throttle hold switch (e.g. HOLD) in "Switch" of the complex mixer page?
03 Jan 2014 06:45 - 03 Jan 2014 06:46 #17819
Complex mixer last page -> mux=replace, curve = fixed, scale=-100, switch=any used as THROTTLE HOLD switch.
Last edit: 03 Jan 2014 06:46 by vlad_vy.
Time to create page: 0.043 seconds
