How to change THR display value ?
07 Apr 2013 13:39 #8682 by geehome
How to change THR display value ? was created by geehome
Hello, I want to see a display value of the THR has 0/100 and not -100/100 on my home page, How to make it please ?
And thank again for your great work ;)
07 Apr 2013 13:56 - 07 Apr 2013 13:57 #8684 by vlad_vy
Replied by vlad_vy on topic How to change THR display value ?
You can use any unused channel to setup:
1) Mix: Simple
2) Src: THR
3) Curve: 1-to-1
4) Scale: 50
5) Offset: 50
And select this channel for a box at Main page config.
Will be nice to use for that a virtual channel, but at current time it's impossible to display virtual channel at boxes.
Issue #280
bitbucket.org/PhracturedBlue/deviation/i...-at-main-page-config
Last edit: 07 Apr 2013 13:57 by vlad_vy.
07 Apr 2013 13:59 #8685 by FDR
Replied by FDR on topic How to change THR display value ?
Even better to use the Ch3 (or Ch1 depending on the protocol) as the source...
07 Apr 2013 14:09 #8686 by vlad_vy
Exactly, this way you get output value, not stick position.
02 Jan 2014 17:28 #17753 by yidc
Replied by yidc on topic How to change THR display value ?
I'm now using virtual channel to display +ve throttle value (ch3)
But when throttle hold is ON, virtual channel will ignore this and still display ch3 value
any idea on this?
I also checked channel monitor, when throttle hold is ON, ch3 always show -100%, but virtual channel still show +ve value
hummmmmm strange :S
02 Jan 2014 17:37 #17755 by vlad_vy
If you use THR as the source for virtual channel it is throttle stick position. You can try to use CH3.
03 Jan 2014 02:04 #17800 by yidc
vlad_vy,
Yes I'm already using CH3 as source of my virtual channel.
Like what I said before, when throttle hold is ON, channel monitor shows CH3 always show -100%, but virtual channel still show +ve value
03 Jan 2014 04:04 #17807 by vlad_vy
Probably you use channel safety for throttle hold and it applied after mixer. Try to create one more complex mixer page for throttle and use it for throttle hold.
03 Jan 2014 06:42 #17818 by yidc
Yes u're correct, I'm using channel safety for THR at this moment
How do I use complex mixer as throttle hold? Choose the throttle hold switch (e.g. HOLD) in "Switch" of the complex mixer page?
03 Jan 2014 06:45 - 03 Jan 2014 06:46 #17819 by vlad_vy
Complex mixer last page -> mux=replace, curve = fixed, scale=-100, switch=any used as THROTTLE HOLD switch.
Last edit: 03 Jan 2014 06:46 by vlad_vy.
Time to create page: 0.153 seconds
