DEVO12S
21 May 2020 10:15 #76343 by billmester
DEVO12S was created by billmester
I just got a Devo12S used with deviation installed, so my trusty D10 will retire. Transferred the models successfully, all is working fine.
Now I have a bunch of questions, please help me if you can:
- main screen button icons: how to add more? On the D10 I just copied files into the media folder... how does it work here? That would be the most important.
- how to upgrade to latest version? I have done all steps installing the drivers, etc on Win10 and still my tx is not visible from the program. Possibly I am not aware how to set this TX to program mode...?
- new to me: here you can have backgrounds or themes, how to change/customize that?
- I knew how to change the splash screen on D10 but here... how to do it?
(This is only new to me... so if these are already discussed somewhere, please point me to it :)
bm
21 May 2020 16:27 #76345 by -=Hubi-Dirk=-
Replied by -=Hubi-Dirk=- on topic DEVO12S
Good choice, Billmester. I love my 12s :)
Here you will find the answer to your question: deviationtx.com/forum/custom-skins/2548-...-for-themers?start=0
Cheers
Dirk
21 May 2020 16:47 #76346 by vlad_vy
Replied by vlad_vy on topic DEVO12S
You can create folder "mymedia" and place custom "config.ini", "sound.ini", "voice.ini", "toggle3.bmp".
21 May 2020 17:00 - 21 May 2020 17:02 #76347 by -=Hubi-Dirk=-
That´s right Vlad, but when you like to change the splashscreen for instance, you have to create a new lib-file. Or is there an other way?
Last edit: 21 May 2020 17:02 by -=Hubi-Dirk=-.
21 May 2020 20:07 #76348 by billmester
Replied by billmester on topic DEVO12S
Okay, so far I have a bunch of icons loaded into the mymedia folder, and it works.
Now, onto the more difficult steps :)
21 May 2020 21:08 #76349 by billmester
Managed to upgrade to latest nightly - the trainer switch... aaaargh :)
Next step: building a new lib, but I keep getting the \\ error not making the output file. I keep trying
22 May 2020 03:52 #76352 by vlad_vy
Probably you need place fake Devo12.bmp file in media folder.
deviationtx.com/forum/custom-skins/2548-...hemers?start=0#49415
22 May 2020 08:22 #76353 by billmester
Hi vlad_vy,
thanks, so, now I can build libraries :)
Here comes my next question:
-a normal .lib is approx 2mb, if I add a splash screen it will get bigger and I do not know if there is enough storage space... is there? what is the max size for splash? what is the max lib size?
I want to avoid failed upload and bricking the tx... :)
22 May 2020 08:23 #76354 by billmester
I also like the dark theme from "Lyndros", but does not display the text menus right. I saw this as an issue in the forums but the solution is not yet working.
22 May 2020 08:25 #76355 by billmester
so background file should be named "Devo12.bmp" or "backgrnd.bmp"?
splash is "splash.bmp"?
22 May 2020 09:39 #76356 by vlad_vy
The lib reside in "Parallel Flash: S29GL128P10TFI01 16MB FSMC accessible NOR Flash".
The background file should be named "backgrnd.bmp", "Devo12.bmp" is a fake file for lib build utility.
24 May 2020 17:11 #76361 by billmester
I got lots of icons and the latest nightly. So far so good.
Lib maker runs.... but so far I made a bunch of .lib-s but none of them were complete (all were with missing text and no splash...), only the original from the nighly build works fine.
At the moment I gave up a little bit of giving a new splash and a new background... maybe I try again soon.
Thanks for the help guys
25 May 2020 04:50 - 25 May 2020 05:04 #76362 by vlad_vy
I think that something wrong with latest lib build utility. Try to use next post attachments to solve your problem:
www.deviationtx.com/forum/builds/6407-de...cols?start=460#73852
Last edit: 25 May 2020 05:04 by vlad_vy.
25 May 2020 15:17 #76367 by billmester
This is how I tried... but failed. So I'll try again.
I sent a pm.
Time to create page: 0.056 seconds
