DEVO12S
- billmester
21 May 2020 10:15 #76343
by billmester
DEVO12S was created by billmester
I just got a Devo12S used with deviation installed, so my trusty D10 will retire. Transferred the models successfully, all is working fine.
Now I have a bunch of questions, please help me if you can:
- main screen button icons: how to add more? On the D10 I just copied files into the media folder... how does it work here? That would be the most important.
- how to upgrade to latest version? I have done all steps installing the drivers, etc on Win10 and still my tx is not visible from the program. Possibly I am not aware how to set this TX to program mode...?
- new to me: here you can have backgrounds or themes, how to change/customize that?
- I knew how to change the splash screen on D10 but here... how to do it?
(This is only new to me... so if these are already discussed somewhere, please point me to it
bm
bm
- -=Hubi-Dirk=-
21 May 2020 16:27 #76345
by -=Hubi-Dirk=-
Replied by -=Hubi-Dirk=- on topic DEVO12S
Good choice, Billmester. I love my 12s
Here you will find the answer to your question: deviationtx.com/forum/custom-skins/2548-...-for-themers?start=0
Cheers
Dirk
Cheers
Dirk
- -=Hubi-Dirk=-
- billmester
- billmester
22 May 2020 03:52 #76352
Replied by vlad_vy on topic DEVO12S
Probably you need place fake Devo12.bmp file in media folder.
deviationtx.com/forum/custom-skins/2548-...hemers?start=0#49415
- billmester
22 May 2020 08:22 #76353
by billmester
Replied by billmester on topic DEVO12S
Hi vlad_vy,
thanks, so, now I can build libraries
Here comes my next question:
-a normal .lib is approx 2mb, if I add a splash screen it will get bigger and I do not know if there is enough storage space... is there? what is the max size for splash? what is the max lib size?
I want to avoid failed upload and bricking the tx...
- billmester
- billmester
- billmester
24 May 2020 17:11 #76361
by billmester
I got lots of icons and the latest nightly. So far so good.
Lib maker runs.... but so far I made a bunch of .lib-s but none of them were complete (all were with missing text and no splash...), only the original from the nighly build works fine.
At the moment I gave up a little bit of giving a new splash and a new background... maybe I try again soon.
Thanks for the help guys
25 May 2020 04:50 - 25 May 2020 05:04 #76362
I think that something wrong with latest lib build utility. Try to use next post attachments to solve your problem:
www.deviationtx.com/forum/builds/6407-de...cols?start=460#73852
Last edit: 25 May 2020 05:04 by vlad_vy.
Time to create page: 0.199 seconds
