Settings for Walkera V450D03 with RX2703H-D needed
03 May 2013 07:56 #9495 by PKB
Thats my first post, so hi to all.
I never needed to ask anything here, cause all my needs were posted.
But this time i haven't found settings for the Walkera V450D03 (the plastic one) with RX2703H-D.
Anyone can help me with that? Can i use any alternatives?
Thanks and have a nice day
Peter (PKB)
04 May 2013 15:02 - 04 May 2013 15:02 #9544 by clearprop88
Replied by clearprop88 on topic Settings for Walkera V450D03 with RX2703H-D needed
Somewhere back in the config. files there's a setup for a V450D01. The D03 should be similar, if not the same. I would use that as a starting point.
Last edit: 04 May 2013 15:02 by clearprop88. Reason: corr
05 May 2013 02:00 #9570 by Hexperience
Replied by Hexperience on topic Settings for Walkera V450D03 with RX2703H-D needed
Not if the D01 is using a 2702 rx. That rx is completly different.
I can post mine when i get to my pc but really it only takes a few minutes to do a model config...
05 May 2013 09:23 #9587 by Fernbediener71
Replied by Fernbediener71 on topic Settings for Walkera V450D03 with RX2703H-D needed
Hi! Here are my settings. I have a NEW V450D01 with the 2703-D, should be the same for the D03.
Before using Fmode 1+2 check them, i don't use these settings at the moment. The heli can 3D but the pilot not so far ;-)
06 May 2013 20:19 - 15 May 2013 13:19 #9628 by hellboy
Last edit: 15 May 2013 13:19 by hellboy.
16 Jul 2013 13:22 #12267 by Hexperience
As requested, my devo8 v450d03 config.
16 Jul 2013 14:43 #12269 by evo165
Hi sir, thank you for sharing. :)
Can you explain how do you use the Fmod 1 and fmod 2 differently?
The fmod 1 is using throttle of only 30% at mid stick.
The fmod 2 is using throttle of 90% atmid stick.
When switching between the fmod 1 and 2, will the heli jumping/dropping?
Hope to seek and learn more from you, sir.
16 Jul 2013 16:22 - 16 Jul 2013 16:26 #12270 by Hexperience
Yes, the heli would jump up. If you are new to flying I would suggest you just copy the settings from Fmod 1 to fmod 2. That way you don't accidentally switch to it.
To use F2 I would start in f0 and as the heli is getting up to speed but still at zero pitch, flip to f2. The heli esc will then pump the same power into the motor no matter what the pitch is. (At this point you might want to look into governor mode)
Long story short, I'm still not at the point where I fly in F2. I start in f0, then go to F1 so I can do some flips and rolls and a little bit of inverted. So if you're not at the 3D stage yet stick with f0 and f1.
--- EDIT ---
Please check the throttle in F1. I think you should find that it's not at 30%. It should be +25 which is 62.5%... If it's not adjust it.
Also, I never used the standard gui only the advanced gui.
Last edit: 16 Jul 2013 16:26 by Hexperience.
16 Jul 2013 23:31 #12273 by evo165
I understand now bro Hex. Thank you for enlighten me on this. Yup, my bad... It is +25 value in my Devo 10. ;)
My last question, people are always telling me when going idle up f1 or f2...
It will be better to use higher head speed value of +70 to +100 (Deviation value) at mid stick. This give more constant speed on the head rather than varying the motor speed & pitch together if mid stick throttle is set too low. True?
In fact, I am just learning to fly normal sport & scale flying... No 3D for me yet... People advice the above will give me longer flight time due to constant head speed... Is this true?
I have so much more to learn... :)
22 Nov 2013 01:33 #15732 by Diaz
Sir : hi thank you for the file how do I load it to the deviation in my devo s8 ? Please help. Erik :)
Erik
22 Nov 2013 01:37 #15733 by Diaz
Hi don't know if I sent u this but can you tell me how to use or down load the file into my radio ? Please help thanks Erik
Erik
22 Nov 2013 05:09 #15734 by FDR
Please read the manual!
BTW you turn on the tx in USB mode (holding the ENT), and simply copy it to the models directory renamed to a valid modelXX.ini filename...
22 Nov 2013 05:10 #15735 by Hexperience
Put the devo in usb mode and copy the file to the models folder. Be sure to changethe filename to a model number you are not using because it will overwrite the file.
21 Sep 2014 16:06 #25755 by CUZN_J
My trouble is devo7e transmitter, I saw in a post here but can't find again now, that [ Hexperience ] posted, "heli jumps", and went on, that is what I have happening, when I bring the v450d03 throttle up, it begin to make left side drift, when I try to correct with right ale. it jumps about 8 to 12 inches off the ground, I know that the devo 7e trans, has one less switch action than the 7 does. Does any one know whats causing this??
Thanks for all the great info that has been posted on this heli.
14 Oct 2014 07:19 #26077 by aimHigher
Can some post some very very docile settings for my devo 7E in both mode 1 & 2 so I dont mess up my heli on its flight again?
03 Apr 2019 18:43 #73673 by CWSMTB
I also need help in understanding how my Devo7 should be set up. It was mentioned that someone provided a file, is there a place to get the file?
Thank you
Time to create page: 0.057 seconds
