Walkera V450D01/D03 - Standard Settings
08 Jan 2014 02:09 - 30 Apr 2014 15:22 #18179 by Tom Z
  • Throttle hold on the RUDD D/R switch.
  • 7 Point Throttle and Pitch Curves.
  • TX Power=100mW
  • Channels=7
  • Protocol=DEVO
  • No Fixed ID
  • Stick Mode 2
  • If you need Stick Mode 1, 3, or 4 load the model into your transmitter then change the Stick Mode in the transmitter settings.
    Model 18 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Fixed ID
My model does not use a Fixed ID.
If you used a Fixed ID with the original Walkera firmware you must clear the Fixed ID in the Receiver with the Bind Plug.
If you don't clear the Fixed ID the model will not bind.
If you want to use a Fixed ID you can enter the same Fixed ID you had for the original Walkera firmware.
Example: Your original Walkera firmware Fixed ID was: 123456
Assign the Deviation Fixed ID: 123456
You can also assign any Fixed ID that you want to use. You don't have to use the original Walkera firmware Fixed ID. Clear the Fixed ID in the Receiver with the Bind Plug then assign any Fixed ID that you want to use.
Throttle Curve
Normal: Linear Curve
ST-1: V Shaped Throttle Curve
ST-2: 100% Flat Across
Pitch Curve
Normal: -3* negative pitch. Zero degrees pitch at mid stick.
Gyro Gain
Set to 60% for Normal and Stunt modes. This value is equal to the Walkera firmware value of 80% gyro gain.
DR/EXPO
Switch Position
0- ELEV D/R = 70% EXP +30%
0- AILE D/R = 70% EXP +30%
RUDD D/R = 100% EXP LIN
Switch Position
1- ELEV D/R = 100% EXP +30%
1- AILE D/R = 100% EXP +30%
Last edit: 30 Apr 2014 15:22 by Tom Z.
29 Apr 2014 20:31 #22791 by pet139
Replied by pet139 on topic Walkera V450D01/D03 - Standard Settings
Hi tom
firstly,I want to thank you for your dedication and tutorials that have helped me to be able to configure the models.
but I would like to ask you one thing, I could not get this model correctly bind with the original receiver of walkera.
but I can not bind it to any way, you know this model has v450d03 FBL Receiver: RX-2703H-D, and i don't know what protocol i must to put for binding
I appreciate if you can help me and thank you very much for your attention.
Greetings.
29 Apr 2014 21:45 #22792 by pet139
hello again tom,
I've already solved out and finally I managed to bind It successfully, and Now work all right. the problem was that to get your settings in the menu of protocol , It was a bind code(667766),only a restored It and new one was binding.
thanks for your contribution.
Best regards .
30 Apr 2014 00:07 #22793 by Tom Z
Replied by Tom Z on topic Walkera V450D01/D03 - Standard Settings
Your welcome.
That's good you got it working.
I was going to say to clear the fixed ID in the receiver with the bind plug.
All my models don't use any fixed ID. I leave the choice up to each person if they want to use a fixed ID or not.
29 Jun 2014 12:17 #24292 by sfersystem
Replied by sfersystem on topic Walkera V450D01/D03 - Standard Settings
I'm using RX1002-W and Copter X cx-3x1000 fbl gyro with a DEVO10-W.
I try using this template to control my HK450 FBL and i think all is quite ok, but i can't find a way to switch the AVCS to NORMAL mode on my Gyro.
I saw this post, but i saw nothing that can help me.
How to setup FBL
Thank you.
14 Jul 2014 11:29 #24572 by Tom Z
I have the gyro gain set to 60% for Normal and Stunt modes. This value is equal to the Walkera firmware value of 80% gyro gain.
If you want to switch the AVCS to NORMAL mode you would have to change the settings below. You would need to assign the gyro values to a switch.
I don't have your helicopter so I can't tell you the values you would need but you could try different values until you get the ones that will work for you.
[channel7]
template=complex
[mixer]
src=Ch7
dest=Ch7
scalar=60
curvetype=fixed
[mixer]
src=Ch7
dest=Ch7
switch=FMODE1
scalar=60
curvetype=fixed
[mixer]
src=Ch7
dest=Ch7
switch=FMODE2
scalar=60
curvetype=fixed
15 Jul 2014 05:02 - 15 Jul 2014 05:03 #24587 by sfersystem
Thank you for your help Tom Z. I arrived in the meantime
I've open a new thread for my helicopter here
Last edit: 15 Jul 2014 05:03 by sfersystem.
02 Mar 2015 16:17 #29265 by megre
Replied by megre on topic Walkera V450D01/D03 - Standard Settings
спасибо большое за информацию, вы меня просто спасли. но у меня devo 6s, помогите настроить hold, на переключатель gear. где и что поменять? заранее благодарю.
Time to create page: 1.000 seconds
