JJRC 1000A Quadcopter (V202)
13 Sep 2014 13:45 - 13 Sep 2014 13:56 #25640 by MAZ
JJRC 1000A Quadcopter (V202) was created by MAZ
Hi, see below for a JJRC 1000A model file.
The model name will be "JJIRC POLY", you can change to your particular needs.
This is using the "Hubsan X4 for 7e 10" icon located at:
http://www.deviationtx.com/forum/bw-icons-for-devo-7e-10/1615-hubsan-x4-for-7e-10
Requires the NRF24L01 module:
http://www.banggood.com/DEVO-Transmitter-Tuner-Modified-For-FBL80-FBL100-WLtoys-V922-p-89812.html
Here is a direct link to the board:
http://www.banggood.com/JJRC-1000A-RC-Quadcopter-Part-Receiver-Board-1000A02-p-928365.html
And a direct link to the BNF quad:
http://www.banggood.com/JJRC-1000A-24G-6-Axis-Gyro-RC-Quadcopter-BNF-p-926458.html
File Attachment:
File Name: model1-JJRC_1000A.ini
File Size:4 KB
Last edit: 13 Sep 2014 13:56 by MAZ.
22 Oct 2014 23:13 #26146 by crash7X
Replied by crash7X on topic JJRC 1000A Quadcopter (V202)
Thank you. This was a big help.
I find this radio/protocol pair works for a micro quadcopter I have labeled
WLtoys NO.V282 SKYLARK
incredible nano-sized r/c quadcopter
It came in a handsome retail box, too. Anyway I mention it here in case another searches these pages trying to do the same thing!
04 Mar 2015 02:34 - 04 Mar 2015 02:38 #29306 by peanut_man
Replied by peanut_man on topic JJRC 1000A Quadcopter (V202)
Here's mine which is a modified from above with auto flip. The file comes out of Devo 8S. Some notable controls:
Channel 5 controls the LEDs, it is mapped to GEAR 0 = ON, GEAR 1 = OFF
Channel 6 controls the auto-flip, it is mapped to RUDD D/R 0 = OFF (no flip), RUDD D/R 1 = ON (auto flip)
FMODE 0 = 60% AIL and ELE
FMODE 1 = 80% AIL and ELE
FMODE 2 = 100% AIL and ELE
Auto Flip works at FMODE 2 (100%) and RUDD DR/R 1, at this setting if you give full right stick movement the quad will flip in that direction. Pretty cool. I like this setting so far.
Last edit: 04 Mar 2015 02:38 by peanut_man. Reason: adding tx model
23 Jul 2015 16:12 #35866 by Zaphod
Replied by Zaphod on topic JJRC 1000A Quadcopter (V202)
From what I've read the 1000A has headless mode. What channel is used to activate headless mode tho? Any suggestions?
23 Jul 2015 16:21 #35867 by Doug40
Replied by Doug40 on topic JJRC 1000A Quadcopter (V202)
Zaphod wrote: From what I've read the 1000A has headless mode. What channel is used to activate headless mode tho? Any suggestions?
Check this thread below: JJRC1000 questions
Look for the posting by Racemaniac. He has a model file and data about what controls what.
23 Jul 2015 22:44 #35876 by RedSleds
Replied by RedSleds on topic JJRC 1000A Quadcopter (V202)
Headless mode is assigned to channel 9.
23 Jul 2015 23:04 #35878 by Zaphod
Thanks guys! Very much appreciated :)
13 Dec 2015 13:02 #40873 by staryk
Replied by staryk on topic JJRC 1000A Quadcopter (V202)
Hi all,
Jjrc 1000 ( old, without A ) does not supported by Deviation?
Can't bind ...
13 Dec 2015 18:07 - 13 Dec 2015 18:09 #40880 by RedSleds
staryk wrote: Hi all,
Can't bind ...
The JJRC JJ-1000 is not supported in the Deviation v4.0.1 released version, but is supported by the Nightly Builds. Flash a recent Nightly Build firmware, round up a model config/ini file for the JJ-1000, and all will be good.
Last edit: 13 Dec 2015 18:09 by RedSleds.
27 Dec 2015 05:01 #41167 by magic_marty
Replied by magic_marty on topic JJRC 1000A Quadcopter (V202)
Is anybody experiencing weird control in headless mode? On mine when in headless mode if i push forward the quad moves forward and to the right like i am pushing the stick to the top right corner..Any ideas whats going on anybody?
08 Apr 2016 10:10 #46105 by naude
Replied by naude on topic JJRC 1000A Quadcopter (V202)
peanut_man wrote: Here's mine which is a modified from above with auto flip. The file comes out of Devo 8S. Some notable controls:
Hello is it possible to change my jjrc x1 file for Devo 7e as your but in pheasants so that only fmod0 and fmod1 be used fmod0 clearance to 100% and 60% fmod1 if you like it.
26 Feb 2021 00:52 #77275 by JH66
Replied by JH66 on topic JJRC 1000A Quadcopter (V202)
I've been flying a modified JJRC JJ1000 quad for quite some time now. In fact I have a few of them with graphite bodies. I'm brand new to open TX but just bought a Radio Master TX 16S to want to know if anybody's got a download to make the JJ1000 work with the radio master TX16 radio.
Time to create page: 0.050 seconds
