Blade NANO CP S DEVO 10 With SAFE
- Jasenk
This INI for the NANO CP S is based off of Jousha's file model11-2-3.ini. Thank you for the start! The most confusing part was that I was in the wrong bind mode "computer mode" I think. Once I got it to bind normal then things made sense. I set mine up with the STICKY throttle as well. Not sure if that's needed though.
FMODE0=Stability (Blue LED)
FMODE1=Agility (Red LED)
FMODE2=3D (Red LED)
ELE RR0=Normal flight modes (Blue and Red LED depending on mode)
ELE DR1=SAFE (for all Flight Modes, ALL Blue LED)
RUD DR1=Trainer Mode [ppm-in} , It's a gift for my father so I might do trainer mode to start him off.
I've also changed some things to "template=complex" instead of "template=expo_dr" it's just easier for me that way.
I hope this helps some Devo 10 users. A big thanks to the Devo 8 users and everyone else supporting this activity!
-Jasen
- Piero1
Jasenk wrote: Ok, I worked it out. Took all day due to the fact I have trouble with Throttle[channel1] vs Collective[channel6] distinguishing between the two. I had to change the Devo 8 [gui-320x240] to Devo 10 [gui-128x64]. Switches all lined up, but I did change switch assignments.
FMODE2=3D (Red LED)
Hello, this configuration may work with a devo7e? Wishes for end of year
- Jasenk
-Jasen
- Jasen
Model Configs
- Blade NANO CP S DEVO 10 With SAFE
