Blade NANO CP S DEVO 10 With SAFE
21 Dec 2015 01:21 #41074 by Jasenk
Blade NANO CP S DEVO 10 With SAFE was created by Jasenk
Ok, I worked it out. Took all day due to the fact I have trouble with Throttle[channel1] vs Collective[channel6] distinguishing between the two. I had to change the Devo 8 [gui-320x240] to Devo 10 [gui-128x64]. Switches all lined up, but I did change switch assignments.
This INI for the NANO CP S is based off of Jousha's file model11-2-3.ini. Thank you for the start! The most confusing part was that I was in the wrong bind mode "computer mode" I think. Once I got it to bind normal then things made sense. I set mine up with the STICKY throttle as well. Not sure if that's needed though.
FMODE0=Stability (Blue LED)
FMODE1=Agility (Red LED)
FMODE2=3D (Red LED)
ELE RR0=Normal flight modes (Blue and Red LED depending on mode)
ELE DR1=SAFE (for all Flight Modes, ALL Blue LED)
RUD DR1=Trainer Mode [ppm-in} , It's a gift for my father so I might do trainer mode to start him off.
I've also changed some things to "template=complex" instead of "template=expo_dr" it's just easier for me that way.
I hope this helps some Devo 10 users. A big thanks to the Devo 8 users and everyone else supporting this activity!
-Jasen
29 Dec 2015 19:54 #41254 by Piero1
Replied by Piero1 on topic Blade NANO CP S DEVO 10 With SAFE
Jasenk wrote: Ok, I worked it out. Took all day due to the fact I have trouble with Throttle[channel1] vs Collective[channel6] distinguishing between the two. I had to change the Devo 8 [gui-320x240] to Devo 10 [gui-128x64]. Switches all lined up, but I did change switch assignments.
FMODE2=3D (Red LED)
Hello, this configuration may work with a devo7e? Wishes for end of year
30 Dec 2015 18:59 #41264 by Jasenk
Replied by Jasenk on topic Blade NANO CP S DEVO 10 With SAFE
I think it will, but you may need to change some switch callouts and the GUI at the end staring with [gui-128x64] and the rest until the end.
-Jasen
31 Dec 2015 16:28 #41286 by Jasen
Replied by Jasen on topic Blade NANO CP S DEVO 10 With SAFE
Nice work, I am using it with my Devo10. All modes are working nicely. I had a couple in-door, and few out flight in 3d mode. I did remove the expo, witch works out better for my fingers.
Time to create page: 0.110 seconds
