Lizard95 Devo7e DSMX
06 Sep 2017 13:59 #64239 by Alliaume
Lizard95 Devo7e DSMX was created by Alliaume
My model file for Lizard95 with Devo7e (without modification).
  • Protocol : DSMX
  • Hold (Ch5) : In bF, I configure this channel for Arming/Disarming
  • Fmod (Ch6) : 0 : Level mode
  • Fmod (Ch6) : 1 : Accro mode
  • 3 timers defined
  • At startup, Tx display a warning if : THR is not at -100 or Hold != 0
  • Icon in attachments
You need to define rxrange in betaflight configurator :
From CLI tab (betaflight configurator) type :
rxrange 0 1159 1841
rxrange 1 1159 1841
rxrange 2 1159 1841
rxrange 3 1159 1841
save
At the first connection between Devo7e and Lizard, you must follow binding protocol :
set spektrum_sat_bind = 9
Then type :
save
Remove USB cable from Lizard, wait a second and reconnect cable.
In devo7e, Menu -> Model Menu -> Model Setup -> Click on "Bind" button.
From CLI, type
set spektrum_sat_bind = 0
save
Time to create page: 0.038 seconds
